HC1: buster_current_5.4.19 poor samba speed vs stretch_legacy_4.14.170
On Odroid HC1 512GB SSD with Armbian_20.02.1_Odroidxu4_stretch_legacy_4.14.170 I've got great SSD SATA samba write speed - 110 MB/s! But I have poor only 35MB/s on Armbian_20.02.1_Odroidxu4_buster_current_5.4.19_minimal
With Armbian_20.02.1_Odroidxu4_bullseye_current_5.4.19 I have the same poor 35MB/s speed.
I've done three identical installations using my checklist:
#Armbian install on Odroid HC1
# Flash   Armbian_<>.img
#Upgrade
    apt update
    apt upgrade
#Move rootfs to SSD
#   Make rootfs partition
        fdisk /dev/sda
#   Make filesystems
        mkfs.ext4 /dev/sda1
        mkfs.ext4 /dev/sda2
#   Mount it to specific directory to use your SSD.
#   Make new directories for SSD.
        mkdir -p /media/system
        mkdir -p /media/data
#   Use /media/systemdrive as a root partition, and /media/data as a data partition.
        mount /dev/sda1 /media/system
        mount /dev/sda2 /media/data
#   Check if it is mounted properly.
        df -h
#   /boot/armbianEnv.txt
board_name=hc1
rootdev=UUID=559245cc-c0b4-4f7d-a128-99d78f13c215
rootfstype=ext4
verbosity=1
 9b1636f3-67e4-4324-b080-678263b5e3bb
#   /etc/fstab
#UUID=289c15a6-61a0-405f-b66e-6b7b13c350ef / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
/dev/sda1 / ext4 defaults,noatime 0 1
/dev/sda2 /media/data ext4 defaults 0 2
#   Copy a root partition
        rsync -axv / /media/system
#   Check rootfs mount piont
        reboot
        lsblk -f
#Install Cockpit
apt-get install cockpit cockpit-networkmanager cockpit-dashboard cockpit-storaged cockpit-packagekit cockpit-docker
    Change hostname
#Install samba
    apt install samba
    systemctl status smbd - test deamon
    cp /etc/samba/smb.conf /etc/samba/smb-default.conf
#    Insert in /etc/samba/smb.conf
[data]
    comment = No limits here.
    path = /media/data
    guest ok = yes
    browseable = yes
    writable = yes
    create mask = 0644
    directory mask = 0755
    force user = publicshare
    adduser --system publicshare
    chown publicshare /media/data
I think something wrong with 5.4.19 kernel builds.
I need to move forward and begin to install apps, but I'm stuck in this testing loop :)
Any advice would be appreciated.
Edited by vinser
clarification of the Topic
We needed months to hopefully make it stable and usable which you obviously didn't even notice.
https://github.com/armbian/build#support
https://github.com/armbian/build#contribute
https://github.com/armbian/build#social
Igor, I really appreciate  the work of software developers, as I myself do it as far as my abilities and capabilities are. I did not want to offend anyone. I just wanted to report the results based on the tests I did and I hoped to get a bit info about that I couldn’t find on the forum.
I didn’t register an issue on github but wrote it there. Isn't this a support forum?
By the way I've finished with Armbian_20.02.1_Odroidxu4_buster_legacy_4.14.170 just now and as expected it works well - 100 - 110MB/s transfer speed from Windows 10 PC to HC1 sumba share
Kind regards
Use (old) kernel builds that are much more tested.
If the answer is not on the internet its clarifying is usually related with high costs (many things is unknown or changing fast) which is why such support is almost never available to end users.
Since your are obviously new, I only asked you to check our support term first:
Good choice. Modern kernel is getting better, but can't tell you when "everything" will work.
