HD playback and spdif passtrouth not working together
damien78
I want to use my cubietruck to play the video in HD and with spdif pass-trougth and I want use mopidy.
with last armbian jessie desktop :
with mplayer2 :
pass-trougth is ok  but video is too slow
with mpv :
I heard a very loud noise at the output of the amplifier is not DTS decoding and is transmitted as the pcm.--> it is a kernel problem: the driver sends a sound that is not recognized by the amplifier. the SPDIF sound format is limited to 24 bits
video is OK.
mopidy is OK
with last armbian xenial: it work because mpv is very old
with mplayer2 :
pass-through and video is ok but kernel panic when I put the video paused--> kernel bug solved : see http://forum.armbian.com/index.php/topic/1396-kernel-panic-when-playing-video-with-spdif-audio-output/
with mpv :
video is OK but same issue for sound.
mopidy : no sound.
with armbian trusty:
all work but but kernel panic when I put the video paused-> kernel bug solved
This issue is partially solved because work only with old version of mpv (before 0.6)
Link to comment
Share on other sites
