Spider Posted March 9, 2020 Share Posted March 9, 2020 Is it normal? Why Couldn't get bank PG regulator U-Boot SPL 2019.10-armbian (Feb 17 2020 - 08:31:10 +0100) DRAM: 1024 MiB Trying to boot from MMC1 NOTICE: BL31: v2.2(debug):572fcdd-dirty NOTICE: BL31: Built : 08:31:00, Feb 17 2020 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc07ef00, model: OrangePi Lite 2 INFO: ARM GICv2 driver initialized INFO: PMIC: Probing AXP805 on I2C INFO: PMIC: aldo1 voltage: 3.300V INFO: PMIC: aldo3 voltage: 3.300V INFO: PMIC: bldo1 voltage: 1.800V INFO: PMIC: bldo2 voltage: 1.800V INFO: PMIC: bldo3 voltage: 1.800V INFO: PMIC: cldo1 voltage: 3.300V INFO: PMIC: dcdcd voltage: 0.960V INFO: PMIC: dcdce voltage: 1.200V INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.10-armbian (Feb 17 2020 - 08:31:10 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi Lite 2 DRAM: 1 GiB MMC: mmc@4020000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3033 bytes read in 6 ms (493.2 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 291 bytes read in 5 ms (56.6 KiB/s) 32785 bytes read in 14 ms (2.2 MiB/s) 4161 bytes read in 15 ms (270.5 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 7655747 bytes read in 775 ms (9.4 MiB/s) 15687688 bytes read in 1579 ms (9.5 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7655683 Bytes = 7.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 498b2000, end 49fff103 ... OK Loading Device Tree to 0000000049841000, end 00000000498b1fff ... OK Starting kernel ... [ 2.297662] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.304821] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 198 [ 2.311791] sun50i-h6-pinctrl 300b000.pinctrl: pin-198 (5000400.serial) status -517 [ 2.319453] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 198 (PG6) from group PG6 on device 300b000.pinctrl [ 2.330321] dw-apb-uart 5000400.serial: Error applying setting, reverse things back [ 2.541572] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.548826] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 192 [ 2.555873] sun50i-h6-pinctrl 300b000.pinctrl: pin-192 (4021000.mmc) status -517 [ 2.563357] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 192 (PG0) from group PG0 on device 300b000.pinctrl [ 2.574353] sunxi-mmc 4021000.mmc: Error applying setting, reverse things back [ 2.582052] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 2.589282] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 70 [ 2.596240] sun50i-h6-pinctrl 300b000.pinctrl: pin-70 (300b000.pinctrl:70) status -517 [ 2.604594] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.611819] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 198 [ 2.618865] sun50i-h6-pinctrl 300b000.pinctrl: pin-198 (5000400.serial) status -517 [ 2.626612] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 198 (PG6) from group PG6 on device 300b000.pinctrl [ 2.637601] dw-apb-uart 5000400.serial: Error applying setting, reverse things back [ 2.647257] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.654501] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 192 [ 2.661550] sun50i-h6-pinctrl 300b000.pinctrl: pin-192 (4021000.mmc) status -517 [ 2.669035] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 192 (PG0) from group PG0 on device 300b000.pinctrl [ 2.680023] sunxi-mmc 4021000.mmc: Error applying setting, reverse things back [ 2.687515] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 2.694750] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 70 [ 2.701718] sun50i-h6-pinctrl 300b000.pinctrl: pin-70 (300b000.pinctrl:70) status -517 [ 2.710085] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.717319] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 198 [ 2.724368] sun50i-h6-pinctrl 300b000.pinctrl: pin-198 (5000400.serial) status -517 [ 2.732120] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 198 (PG6) from group PG6 on device 300b000.pinctrl [ 2.743111] dw-apb-uart 5000400.serial: Error applying setting, reverse things back [ 2.752766] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 2.760001] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 192 [ 2.767060] sun50i-h6-pinctrl 300b000.pinctrl: pin-192 (4021000.mmc) status -517 [ 2.774548] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 192 (PG0) from group PG0 on device 300b000.pinctrl [ 2.785544] sunxi-mmc 4021000.mmc: Error applying setting, reverse things back [ 3.075680] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 3.083006] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 70 [ 3.090009] sun50i-h6-pinctrl 300b000.pinctrl: pin-70 (300b000.pinctrl:70) status -517 [ 3.098672] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 3.105942] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 198 [ 3.113041] sun50i-h6-pinctrl 300b000.pinctrl: pin-198 (5000400.serial) status -517 [ 3.120854] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 198 (PG6) from group PG6 on device 300b000.pinctrl [ 3.131907] dw-apb-uart 5000400.serial: Error applying setting, reverse things back [ 3.142360] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 3.149644] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 192 [ 3.156704] sun50i-h6-pinctrl 300b000.pinctrl: pin-192 (4021000.mmc) status -517 [ 3.164198] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 192 (PG0) from group PG0 on device 300b000.pinctrl [ 3.175201] sunxi-mmc 4021000.mmc: Error applying setting, reverse things back [ 3.184840] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 3.192143] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 70 [ 3.199107] sun50i-h6-pinctrl 300b000.pinctrl: pin-70 (300b000.pinctrl:70) status -517 [ 3.199593] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 3.214352] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 198 [ 3.214358] sun50i-h6-pinctrl 300b000.pinctrl: pin-198 (5000400.serial) status -517 [ 3.229144] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 198 (PG6) from group PG6 on device 300b000.pinctrl [ 3.229150] dw-apb-uart 5000400.serial: Error applying setting, reverse things back [ 3.250438] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PG regulator [ 3.257692] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 192 [ 3.257699] sun50i-h6-pinctrl 300b000.pinctrl: pin-192 (4021000.mmc) status -517 [ 3.257706] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 192 (PG0) from group PG0 on device 300b000.pinctrl [ 3.272233] sunxi-mmc 4021000.mmc: Error applying setting, reverse things back Armbian 20.02.1 Buster ttyS0 orangepilite2 login: Link to comment Share on other sites More sharing options...
