i have some difficulties to add some boot parameters to the kernel.
From what i read, the most safe procedure is to use the armbian-config tool, that will add the parameters to /boot/armbianEnv.txt file.
As i have understood, the armbianEnv will be readed by the boot.cmd/boot.scr at launch, without need to recompile anything.
I have added the needed parameters using armbian-config, but does not work.
To be precise, the commands that i have to add are:
video=composite-1:d
video=Composite-1:d
I need to disable the drm composite output because my monitor is.....well, not good and the composite output cause a lot of problems.
I have also tried to enable the boot logo changing the value from "disabled" to "enabled", but nothing has changed.
I'm doing something wrong? I miss something?
I have also tried using the procedure described here without success: https://docs.armbian.com/User-Guide_Fine-Tuning/
Can someone help me?
Thanks for the attention and the dedicated time.
Have a good day
I would try "video=composite-1:d".. this goes in over u-boot variables, and they tend to mess up stuff.. cause it's then more like extraargs=video=composite-1:d whereas it should be extraargs="video=composite-1:d"..
So you suggest to change the command to "command" right? I tried it but nothing happen. Maybe your suggestion works, but the command itself doesn't. As i know, all current kernel boot parameter can be found on /proc/cmdline file, but there isn't.
Solution found:
I tried to use some of the texts you suggest, specifically the extraargs=video=composite-1:d (without quotes) works.
Seems that the script look for the extraargs= prefix and add everything next to kernel parameters.
It appear on /proc/cmdline and the command seems to work, now that connector is listed ad "disconnected".
Thanks a lot for the help and the dedicated time!
  • Igor pinned this topic
  • Igor unpinned this topic
