HI,
I have a orange pi zero + with a NAS board (orange pi zero nas) with a msata ssd (kingspec 64 Gb):
But armbian don't releave msata device, because with fdisk command I have:
fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.6 GiB, 15653142528 bytes, 30572544 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x41b78b57
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       8192 30266815 30258624 14.4G 83 Linux
Disk /dev/zram0: 50 MiB, 52428800 bytes, 12800 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 119.1 MiB, 124911616 bytes, 30496 sectors
How I can to do for resolve my problem ?
this is the first time that I try to use ssd msata, so I don't know if device is working (it is new, but I don't have installed until now)
I do not know. From the logs it does not look like it detected anything at all....
/OT: You should not expect very high speed from this MSATA anyways since this board just connects it through USB2 which will limit the throughput to the well known 480Mbit/s.
