Hydro Posted June 8, 2016 Share Posted June 8, 2016 Hi I have a cubieboard 2 and i used cubian but now i need to use jessie so i moved to armbian jessie. I try both vanilla et legacy headless img. I have a razberry connected to gpio and i use ethernet cable. For both img, first boot is ok but after i have a big bug at "stop autoboot". I join two picture from the HDMI output. Sometime after several reboot (hard reboot) it works but not well, for example i can't access to ssh and some services don't work anymore, mysql for example. I try different sd card and when i try cubian x1, it works well (but wheezy ) Thank Link to comment Share on other sites More sharing options...
Igor Posted June 8, 2016 Share Posted June 8, 2016 You have something plugged on serial console? Link to comment Share on other sites More sharing options...
Hydro Posted June 9, 2016 Author Share Posted June 9, 2016 I only have my razberry connect on the top of the cubieboard 2 : Link to comment Share on other sites More sharing options...
Igor Posted June 9, 2016 Share Posted June 9, 2016 You can't use default serial console for this, at least not by default. Reconfigure U-boot or connect this device to some other UART and you will be fine. Link to comment Share on other sites More sharing options...
Hydro Posted June 9, 2016 Author Share Posted June 9, 2016 The other UART are available by default ? My home automation software need to use tty0, is it a problem with another uart ? Link to comment Share on other sites More sharing options...
