Cubieboard 2 problem at boot
Hydro
Hi
I have a cubieboard 2 and i used cubian but now i need to use jessie so i moved to armbian jessie.
I try both vanilla et legacy headless img. I have a razberry connected to gpio and i use ethernet cable.
For both img, first boot is ok but after i have a big bug at "stop autoboot". I join two picture from the HDMI output.
Sometime after several reboot (hard reboot) it works but not well, for example i can't access to ssh and some services don't work anymore, mysql for example.
I try different sd card and when i try cubian x1, it works well (but wheezy  :unsure: )
Thank
You can't use default serial console for this, at least not by default. Reconfigure U-boot or connect this device to some other UART and you will be fine.
