tibibs Posted April 6, 2020 Posted April 6, 2020 Hi, I am fairly new to the SBC board and struggling to begin my setup of the NanoPo NEO Air. This little board is a perfect fit for my project I need to develop. The first problem I encounter is the following: There are no HDMI port. Thus I can't do the basic configuration for my network and allow an SSID access. Does anyone has a solution to preconfigure the WIFI of my Armbian from windows (or Linux if needed)? My second problem will be: I would like to install my system on the EMMC flash to not be dependent of the SD card. Can you confirm I would only need to run the command "nand-sata-install" when I will get access to SSH? Last problem is that I will need to implement a trigger between wifi and AP mode. I have briefly seen some topics about this, some are saying friendly arm have this function natively, others that this function will be develop soon for Armbian and some have some kind of tutorials about it (playing with wpa_supplicant config). What is the state of the art regarding this? Finally but not least, I am trying to get it running with a Bionic image of armbian. If there are some better image to be used, please let me know. I am sorry if those questions seems straightforward but I am not so familiar with Linux and its services nor the SBC world. Thank you for your help and guidance. Tibibs
Igor Posted April 6, 2020 Posted April 6, 2020 For boards that doesn't have HDMI you need to use serial console to login. On this board you have two. 1. Via 3 pin connection https://linux-sunxi.org/UART 2. Via mUSB. Simply power the board via PC USB port and you will get a new serial console to which you connect with a Putty or similar terminal program. That's all. On 4/6/2020 at 2:20 PM, tibibs said: Last problem is that I will need to implement a trigger between wifi and AP mode. I have briefly seen some topics about this, some are saying friendly arm have this function natively, others that this function will be develop soon for Armbian and some have some kind of tutorials about it (playing with wpa_supplicant config). What is the state of the art regarding this? Expand AP can be setup standard way but you can't run STA and AP at once. Not sure if the driver supports this OOB. In any case the performance would be terrible ... On 4/6/2020 at 2:20 PM, tibibs said: If there are some better image to be used, please let me know. Expand No, this is it.
tibibs Posted April 7, 2020 Author Posted April 7, 2020 Hi Igor, thank's for the quick reply. 1. Regarding the WIFI on first boot, after some time I have managed to do it by editing the interfaces file in /etc/network from Ubuntu. it was a relief since I don't want to touch to much to the pins yet. But I am still confusing between network manager and wpa_supplicant. When I do some research, it seems their role is a bit overlapping. Can anyone has an easy explanation to describe the difference between the 2? I know wpa_supplicant is specialized in wireless interfaces, but in my example, no config has been done with it and I am still able to connect my WIFI. Sorry for this beginner question, but what's the role of each and which one is prioritized by the system if overlapping? 2. ok I will check that in the coming days. 3. yes both won't coexist but in my application I would need to be in AP mode and when some conditions are met, switch to STA and connect to a dedicated wifi to run some updates then disconnect. Are there any ways to do this from a script?
Igor Posted April 7, 2020 Posted April 7, 2020 On 4/7/2020 at 12:40 AM, tibibs said: But I am still confusing between network manager and wpa_supplicant. Expand They can co-exists. We prefer Network manager since its novice friendly. On 4/7/2020 at 12:40 AM, tibibs said: in my application I would need to be in AP mode and when some conditions are met, switch to STA and connect to a dedicated wifi to run some updates then disconnect. Are there any ways to do this from a script? Expand Its possible, but this is your job to investigate and code.
tibibs Posted June 21, 2020 Author Posted June 21, 2020 Hi, sorry for the long time since the last update on my topic but I have been very busy and had no time to spare on this project. I managed to restart this a bit and so far still finding some issues even though I did some progress as well I decided to study what is network manager a bit and started from fresh install. I have flashed my SD card with a new image, and created my connections using network manager. for connecting to my router, working like a charm, no problems so far (a first for me as I used to edit the interfaces file). I then added one nmconnection file to create the AP (autoconnect false for the infrastructure mode and true for the hotspot so my hotspot will be chosen at boot) my hotspot file looks like this [connection] id=AERStest type=wifi autoconnect=true interface-name=wlan0 permissions= [wifi] mac-address-blacklist= mode=ap ssid=AERStest [wifi-security] group=ccmp; key-mgmt=wpa-psk pairwise=ccmp; proto=rsn; psk=aersaerstest [ipv4] dns-search= method=shared [ipv6] addr-gen-mode=stable-privacy dns-search= method=auto [proxy] while booting, my SSID shows up, but I am unable to connect. It seems that the client trying to connect doesn't get any IP. I would guess the problem would come from dnsmasq. I can't find any dnsmasq.conf in /etc/ and subfolders. Can you help and give me some directions to further troubleshoot my problem? I am using the image Armbian_20.05.4_Nanopiair_focal_current_5.4.45 thank's a lot for the job you're doing. it is really appreciated and actually make me learn a lot about the linux system. Thank you, Tibibs
tibibs Posted June 22, 2020 Author Posted June 22, 2020 Well, I confirm, the problem comes from the DHCP. I can connect without any pb by allocating my IP manually. I have tried to install udhcp and to enable it, with no success. Am I right with installing udhcp or am I going the wrong way? I am a bit lost as I don't know how Network manager handle the DHCP being the server. Can someone give me the direction? thank you, Tibibs
Solution tibibs Posted June 23, 2020 Author Solution Posted June 23, 2020 Hi, Latest update, I have finally managed to sort it out using the terminal and those commands, adapting it based on my needs. nmcli c add type wifi ifname wifi-device con-name connection-name autoconnect no ssid hotspot-ssid nmcli connection modify connection-name 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared nmcli connection modify connection-name wifi-sec.key-mgmt wpa-psk nmcli connection modify connection-name wifi-sec.psk "le password" nmcli connection up connection-name This new connection is working properly. My guess is that the uuid was needed and I didn't included it >< from there, switching connection will be very easy with the commands nmcli connection down connection1 nmcli connection up connection2 thank's a lot. I would need your help for the next step for sure. Tibibs
