R_R Posted April 11, 2020 Posted April 11, 2020 Hello, I am using OrangePi Zero v1.1 board with 512MB DRAM and 8GB Class4 microSD card. I am trying to flash Ubuntu 18.04 LTS downloaded from Armbian site .. Everything goes well till the login point and then suddenly nothing moves. PS - USB adapter 5V, 1.6 Amp rating FTDI converter std. connected to UART of the board. Heatsink mounted on top of the IC. Please Help resolve the possible issue. Thanks !! Rajat Below is the boot up process as captured. U-Boot SPL 2019.04-armbian (Nov 18 2019 - 23:36:05 +0100) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2019.04-armbian (Nov 18 2019 - 23:36:05 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 512 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 3 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning bus 5 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3798 bytes read in 3 ms (1.2 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 230 bytes read in 2 ms (112.3 KiB/s) 8637198 bytes read in 666 ms (12.4 MiB/s) 7644632 bytes read in 590 ms (12.4 MiB/s) Found mainline kernel configuration 28681 bytes read in 12 ms (2.3 MiB/s) 504 bytes read in 6 ms (82 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 4 ms (123 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4155 bytes read in 4 ms (1013.7 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8637134 Bytes = 8.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 497c3000, end 49ffface ... OK Loading Device Tree to 49753000, end 497c2fff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Loading, please wait... starting version 237 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.31.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: recovering journal /dev/mmcblk0p1: clean, 62595/430592 files, 349924/1900544 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Ubuntu 18.04.3 LTS! [ OK ] Reached target System Time Synchronized. [ OK ] Created slice User and Session Slice. [ OK ] Created slice System Slice. [ OK ] Reached target Slices. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Journal Socket. Starting Set the console keyboard layout... Mounting Kernel Debug File System... Starting Load Kernel Modules... [ OK ] Set up automount Arbitrary Executab…rmats File System Automount Point. [ OK ] Reached target Swap. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Created slice system-serial\x2dgetty.slice. Starting Restore / save the current clock... [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Local Encrypted Volumes. [ OK ] Listening on Journal Audit Socket. [ OK ] Listening on fsck to fsckd communication Socket. Starting Remount Root and Kernel File Systems... [ OK ] Reached target Remote File Systems. [ OK ] Listening on Syslog Socket. [ OK ] Listening on Journal Socket (/dev/log). Starting Journal Service... [ OK ] Listening on udev Control Socket. Starting udev Coldplug all Devices... Starting Create list of required st…ce nodes for the current kernel... Starting Nameserver information manager... Mounting POSIX Message Queue File System... [ OK ] Mounted Kernel Debug File System. [ OK ] Started Load Kernel Modules. [ OK ] Started Restore / save the current clock. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Mounted POSIX Message Queue File System. Starting Create Static Device Nodes in /dev... Starting Load/Save Random Seed... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... [ OK ] Started Nameserver information manager. [ OK ] Reached target Network (Pre). [ OK ] Started Journal Service. [ OK ] Started Load/Save Random Seed. [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. Starting udev Kernel Device Manager... Starting Flush Journal to Persistent Storage... [ OK ] Started Set the console keyboard layout. [ OK ] Reached target Local File Systems (Pre). Mounting /tmp... [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /tmp. [ OK ] Started udev Kernel Device Manager. [ OK ] Found device /dev/ttyGS0. [ OK ] Reached target Local File Systems. Starting Raise network interfaces... Starting Armbian ZRAM config... Starting Set console font and keymap... Starting Create Volatile Files and Directories... [ OK ] Started Set console font and keymap. [ OK ] Started Create Volatile Files and Directories. Starting Network Name Resolution... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Entropy daemon using the HAVEGE algorithm. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Found device /dev/ttyS0. [ OK ] Started Network Name Resolution. [ OK d clean activities. [ OK ] Started Message of the Day. Starting Armbian hardware optimization... [ OK ] Started Discard unused blocks once a week. [ OK ] Reached target Timers. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ OK ] Started resolvconf-pull-resolved.path. [ OK ] Reached target Paths. [ OK ] Started Armbian hardware monitoring. [ OK ] Started Armbian hardware optimization. [ OK ] Reached target Basic System. Starting Resets System Activity Data Collector... Starting Dispatcher daemon for systemd-networkd... Starting rng-tools.service... Starting Login Service... [ OK ] Started D-Bus System Message Bus. [ OK ] Started Login Service. Starting WPA supplicant... Starting LSB: Load kernel modules needed to enable cpufreq scaling... Starting Network Manager... Starting resolvconf-pull-resolved.service... Starting System Logging Service... [ OK ] Started Regular background program processing daemon. [ OK ] Started Resets System Activity Data Collector. [ OK ] Started rng-tools.service. [ OK ] Started WPA supplicant. [ OK ] Started System Logging Service. [ OK ] Started resolvconf-pull-resolved.service. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. Starting LSB: set CPUFreq kernel parameters... [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. Starting Hostname Service... [ OK ] Started Hostname Service. [ OK ] Started Network Manager. [ OK ] Reached target Network. Starting chrony, an NTP client/server... Starting OpenBSD Secure Shell server... [ OK ] Started Unattended Upgrades Shutdown. Starting Permit User Sessions... Starting Network Manager Wait Online... [ OK ] Started Permit User Sessions. Starting Network Manager Script Dispatcher Service... Starting Set console scheme... [ OK ] Started Set console scheme. [ OK ] Created slice system-getty.slice. [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started chrony, an NTP client/server. [ OK ] Started OpenBSD Secure Shell server. [ OK ] Started Dispatcher daemon for systemd-networkd. Starting Authorization Manager... [ OK ] Started Authorization Manager. [ OK ] Started Network Manager Wait Online. [ OK ] Reached target Network is Online. Starting /etc/rc.local Compatibility... Starting LSB: Advanced IEEE 802.11 management daemon... [ OK ] Started /etc/rc.local Compatibility. [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Armbian 19.11.3 Bionic ttyS0 bcil login:
Werner Posted April 11, 2020 Posted April 11, 2020 There should be a newer version available. Could you give that one a shot?
