Hi All,
Ive installed docker via the arbian-config -> Softy option but I don't see the option to remove/uninstall software
Upon trying to remove the software (root) via apt-get/dpkg, I get an error that docker is not installed. What is the procedure for removing software install via Softy?
Board: T95Max+
ArmbianVER: Armbian_20.05.1_Arm-64_buster_current_5.6.2_20200408
19 hours ago, Werner said:
Yeah I ended u coming across this... Good thing I was still dual booting and hadn't installed onto the EMMC.
as I simply erased the sdcard and started from scratch.  On another topic thread I think someone mentioned it would
probably be better practice if softy was just an interface to install the software listed via docker.  This would obviously
make the packages listed in softy easier to uninstall and cut down on the topics related to the issue.
  • Werner locked this topic
