renky Posted April 16, 2020 Posted April 16, 2020 it appears the pins on the esp8266 12e are also on the orange pi one. Can I connect the pins to an armbian orange pi one and then test the esp8266 12e? I want to test if wifi works. Is required software present in armbian? Or should I get an usb adapter https://ae01.alicdn.com/kf/HTB1pm33XifrK1RjSspbq6A4pFXaf.jpg?width=1000&height=1000&hash=2000 and utilize a x86 gnulinux computer? It says the esp8266 12e supports i2c. Does the orange pi one have i2c pins, such that I can test the wifi of the esp8266 12e from an i2c connection on the armbian orange pi one? Is required software present in armbian? Thanks.
NicoD Posted November 3, 2020 Posted November 3, 2020 On 4/16/2020 at 1:33 PM, renky said: it appears the pins on the esp8266 12e are also on the orange pi one. Can I connect the pins to an armbian orange pi one and then test the esp8266 12e? I have no clue about that. I'd say use one that has USB. Connect and program via ardiuno IDE. You can always monitor what is happening with it thru the USB connection.
