Install on S905 (Venz V10, P211 1G/8G)
Calia
Hello everyone,
For the past days i've been trying to install Armbian on my S905 box.
I've been able to backup the system with TWRP through a microSD card.
I've installed Armbian_20.02.0-rc1.037_Aml-s9xxx_buster_current_5.5.0-rc6_desktop_20200205 on the SD card and have been trying ever since to find the right DTB file to boot with.
Searching the forums (and coreelec/libreelec forums) it seems that some of these boxes come with a S905 or S905x SOC, but none of the DTB files i've tried result in anything else than a black screen on boot.
Am i doing something really wrong here? Is it perhaps possible to extract a DTB file for this particular SOC from the android installation the box came with (because any installation on ARM would need that data somewhere).
When i boot into android recovery it says: Amlogic/p211/p211, is that a S905 or S905x?
This copy doesn't make sense, and it won't help you recover after running the installation procedure in eMMC.
p211 -> s905x
p211 -> s905x
I've copied all partitions (including boot, eMMC, etc.) to an SD Card to be able to put all that data back in case i f*ck up the entire system.
I'll try again to use a dtb file for the s905x and let you know how that works out.
  • Werner locked this topic
