I'm having problems installing Armbian on the tx3 mini. I can't boot. I already tested the two dtb for s905w that you have in the folder and none worked. Can someone help me? I'm from Brazil.
  • Igor changed the title to TX3 mini doesn't boot
More details about the boot issue (SD ou USB support, toothpick or android update method, blackscreen or error message...) will be appreciated !
To simplify, describe all steps that you have done to try to install Armbian (maybe as this kind of detailled example: I know this is mine ! :beer:)
Edited by Armin
Tonix TX3 mini
used firmware TX3Mini-20181210.img can boot armbian
if used TX3Mini-S905W-20191008.img firmware boot into android recovery only can't boot armbian
  • Werner locked this topic
