Armbianmonitor:
Device: Orange Pi +2e. Environment one 16GB SD Card and 16GB eMMC onboard.
Output from Armbianmonitor attached.
The eMMC device onboard is always detected as mmcblk2. Irrespective of whether SD Card is present or not or if you boot from SD Card or eMMC.
This is observed only on 20.05 and 20.08 builds. It does not happen on 20.02 build.
[    3.769548] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    3.781702] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.784384] mmc0: new high speed SDHC card at address aaaa
[    3.785778] mmcblk0: mmc0:aaaa JULIE 14.8 GiB
[    3.790317]  mmcblk0: p1
[    3.790822] mmc1: new high speed SDIO card at address 0001
[    3.795670] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    3.915829] mmc2: new DDR MMC card at address 0001
[    3.917341] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    3.918284] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[    3.919325] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[    3.922791]  mmcblk2: p1
[    4.143718] usb 6-1: new full-speed USB device number 2 using ohci-platform
--Rajesh
20.08.0-trunk
trunk builds are generally unsupported.
Do you remember which kernel you were using then? All versions are available as legacy  with 4.19.x and current with 5.4.x.
Current 5.4.x. I think it was 5.4.43 / 5.4.44.
--Rajesh
