Henrik Posted June 12, 2020 Posted June 12, 2020 Hello Team, everytime the paket "linux-buster-root-current-bananapi" is updated, i lose my unattended-upgrades conifg. /etc/apt/apt.conf.d/02-armbian-periodic ist set to default /etc/apt/apt.conf.d/50unattended-upgrades is deleted How can i stop it? dpkg -L linux-buster-root-current-bananapi | grep apt /etc/apt /etc/apt/apt.conf.d /etc/apt/apt.conf.d/02-armbian-compress-indexes /etc/apt/apt.conf.d/02-armbian-periodic /etc/apt/apt.conf.d/71-armbian-no-recommends /etc/apt/apt.conf.d/81-armbian-no-languages /usr/lib/armbian/armbian-apt-updates Thank you
Igor Posted June 14, 2020 Posted June 14, 2020 On 6/12/2020 at 7:01 AM, Henrik said: /etc/apt/apt.conf.d/50unattended-upgrades is deleted Expand Use different name since we are removing 50unattended-upgrades which comes from Debian / Ubuntu ... and you should be fine. 1
Bebef Posted October 10, 2020 Posted October 10, 2020 Well, the 50unattended-upgrades allone can't be the cause. I'm facing the same issues since some time in August, so the change seems plausible. What else are you doing in terms of automated updates that could break it (apart from deleting 50unattended-upgrades)? I did everything I could imagine to fix the issue (including re-installing and re-configuring unattended-upgrades after a thorough cleaup). How could I debug it (beside running sudo unattended-upgrade -d which works just fine every single time)? Did you maybe do something to the timers as well?
Bebef Posted October 12, 2020 Posted October 12, 2020 OK, nevermind. Something blocked the timers from starting. It has been fixed now.
