Termo Posted June 19, 2020 Posted June 19, 2020 (edited) Armbianmonitor: http://ix.io/2pCs update works on 5.4.28-sunxi64, so for sure kernel issue... I fail to start the nfs-kernel-server on my neo2: ● nfs-server.service - NFS server and services Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Fri 2020-06-19 22:50:35 CEST; 57s ago Main PID: 28168 (code=exited, status=1/FAILURE) Jun 19 22:50:35 neo2 systemd[1]: Starting NFS server and services... Jun 19 22:50:35 neo2 rpc.nfsd[28168]: rpc.nfsd: writing fd to kernel failed: errno 111 (Connection refused) Jun 19 22:50:35 neo2 rpc.nfsd[28168]: rpc.nfsd: unable to set any sockets for nfsd Jun 19 22:50:35 neo2 systemd[1]: nfs-server.service: Main process exited, code=exited, status=1/FAILURE Jun 19 22:50:35 neo2 systemd[1]: nfs-server.service: Failed with result 'exit-code'. Jun 19 22:50:35 neo2 systemd[1]: Stopped NFS server and services. and from dmesg: [621412.035437] rpc.nfsd: page allocation failure: order:5, mode:0x40dc0(GFP_KERNEL|__GFP_COMP|__GFP_ZERO), nodemask=(null),cpuset=/,mems_allowed=0 [621412.035472] CPU: 2 PID: 25458 Comm: rpc.nfsd Not tainted 5.4.43-sunxi64 #20.05.2 [621412.035476] Hardware name: FriendlyARM NanoPi NEO 2 (DT) [621412.035481] Call trace: [621412.035498] dump_backtrace+0x0/0x180 [621412.035505] show_stack+0x14/0x20 [621412.035516] dump_stack+0xb0/0xd8 [621412.035528] warn_alloc+0xfc/0x168 [621412.035535] __alloc_pages_slowpath+0x9c4/0x9f0 [621412.035543] __alloc_pages_nodemask+0x214/0x298 [621412.035551] alloc_pages_current+0x80/0xf0 [621412.035561] kmalloc_order+0x1c/0x88 [621412.035624] nfsd_file_cache_init+0x64/0x248 [nfsd] [621412.035660] nfsd_svc+0x198/0x288 [nfsd] [621412.035695] write_threads+0x94/0x110 [nfsd] [621412.035729] nfsctl_transaction_write+0x54/0x98 [nfsd] [621412.035739] __vfs_write+0x18/0x40 [621412.035745] vfs_write+0xb0/0x1d0 [621412.035752] ksys_write+0x64/0xe8 [621412.035759] __arm64_sys_write+0x18/0x20 [621412.035770] el0_svc_common.constprop.2+0x88/0x150 [621412.035777] el0_svc_handler+0x20/0x80 [621412.035785] el0_svc+0x8/0xc [621412.035789] Mem-Info: [621412.035810] active_anon:14680 inactive_anon:13376 isolated_anon:0 active_file:3920 inactive_file:3223 isolated_file:0 unevictable:0 dirty:8 writeback:0 unstable:0 slab_reclaimable:13144 slab_unreclaimable:17259 mapped:4842 shmem:176 pagetables:1074 bounce:0 free:29614 free_pcp:0 free_cma:26079 [621412.035827] Node 0 active_anon:58720kB inactive_anon:53504kB active_file:15680kB inactive_file:12892kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:19368kB dirty:32kB writeback:0kB shmem:704kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no [621412.035831] Node 0 DMA32 free:118456kB min:4396kB low:4980kB high:5564kB active_anon:58768kB inactive_anon:53512kB active_file:15644kB inactive_file:13036kB unevictable:0kB writepending:32kB present:524288kB managed:489208kB mlocked:0kB kernel_stack:3632kB pagetables:4296kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:104316kB [621412.035852] lowmem_reserve[]: 0 0 0 [621412.035861] Node 0 DMA32: 2311*4kB (UMEHC) 571*8kB (UMEHC) 1032*16kB (UMEHC) 740*32kB (HC) 434*64kB (HC) 184*128kB (C) 40*256kB (C) 6*512kB (C) 0*1024kB 0*2048kB 0*4096kB = 118644kB [621412.035910] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB [621412.035917] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=32768kB [621412.035923] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB [621412.035929] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=64kB [621412.035932] 7530 total pagecache pages [621412.035939] 194 pages in swap cache [621412.035945] Swap cache stats: add 24936974, delete 24936777, find 248269/24985229 [621412.035949] Free swap = 48244kB [621412.035952] Total swap = 244600kB [621412.035955] 131072 pages RAM [621412.035958] 0 pages HighMem/MovableOnly [621412.035962] 8770 pages reserved [621412.035965] 32768 pages cma reserved [621412.035972] nfsd: unable to allocate nfsd_file_hashtbl I will try to downgrade kernel and see if this solves the issue Regards Termo Edited June 19, 2020 by Termo found working kernel
Werner Posted June 20, 2020 Posted June 20, 2020 From a quick search through sources and commits I assume it is an upstream regression since on Armbian's side nothing has changed since 5.4.28.
Magnets Posted June 27, 2020 Posted June 27, 2020 I have NFS running on opi PC2 5.4.43-sunxi64 working fine
