I can't seem to mount any drives with journaled user/group quota.
I just get this error:
root@bananapipro:~# mount -o rw,defaults,nofail,user_xattr,noexec,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0 UUID=56790abd-531d-43b7-8cf8-9bfc85105f6a /media/56790abd-531d-43b7-8cf8-9bfc85105f6a
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
If I run the mount command without the quota stuff the drive mounts without any problems and is browseable.
@LarsN
zador.blood.stained just added quota for sunxi-next
but you will need to compile your kernel with http://www.armbian.com/using-armbian-tools/
Ah I see. Could we get it enabled by default, as OpenMediaVault bugs out because not being able to mount ext4 disks/partitions.
I can't read :)
These are the default mount values for OpenMediaVault:
I'll try and compile the kernel with quota enabled and see if it fixes the problem.
Thanks for the super fast replies from both of you.
