I am using: Armbian_5.14_Odroidc2_Debian_jessie_3.14.71
I am a bit stumped....if I run with 3 network interfaces, everything is fine.
If I add a fourth interface...the system locks up...even if the 3rd and 4th interface have no ip address.
They just need to be live!
I have tried 4 drastically different interfaces in case the device driver can't handle it.
Anybody have any thoughts or suggestions??
THank you!
any error messages?   have you tried attaching TTL serial console to look for messages?
Good thinking! Thank you.
Anybody see anything like this now?
Jun 21 14:35:26 localhost kernel: [  243.223660]
Jun 21 14:35:26 localhost kernel: [  243.223781] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.223904] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224028] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224153] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224278] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224403] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224528] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224653] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224778] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.224903] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
Jun 21 14:35:26 localhost kernel: [  243.225028] ERROR::assign_and_init_hc:1264: assign_and_init_hc: Failed to allocate memory to handle non-dword aligned buffer case
