1 1
Arnoud
PWM1 on H5
On the Orange Pi Zero Plus the pwm1 port is available on the header instead of pwm0.
Ik have tried to create a custom overlay but it does create a pwm device but it is not working.
pwm1 is on PA6
I have created a folder: overlay-user in /boot
In this folder I created a sun50i-h5-pwm1.dts file with the following content:
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun50i-h5";
        fragment@0 {
                target = <&pio>;
                __overlay__ {
                        pwm1_pin: pwm1 {
                                pins = "PA6";
                                function = "pwm1";
        fragment@1 {
                target = <&pwm>;
                __overlay__ {
                        pinctrl-names = "default";
                        pinctrl-0 = <&pwm1_pin>;
                        status = "okay";
I converted this file with the command:
sudo dtc -O dtb -o sun50i-h5-pwm1.dtbo sun50i-h5-pwm1.dts
after rebooting a pwmchip is available in the /sys/class/pwm
but if I try to export pwm1 I get an error
arnoud@orangepizeroplus:/sys/class/pwm/pwmchip0$ export sudo sh -c "echo 1 > export"
sh: 1: echo: echo: I/O error
There seems to be a pwm0 but when I start this pwm no pwm output is given
arnoud@orangepizeroplus:cd pwm0
arnoud@orangepizeroplus:/sys/class/pwm/pwmchip0/pwm0$ sudo sh -c "echo 1000000 > period"
arnoud@orangepizeroplus:/sys/class/pwm/pwmchip0/pwm0$ sudo sh -c "echo 500000 > duty_cycle"
arnoud@orangepizeroplus:/sys/class/pwm/pwmchip0/pwm0$ sudo sh -c "echo 1 > enable"
Can someone please give me a hint in what I am doing wrong.
Share this post
Link to post
Share on other sites
OMG. I am looking in the docs of the datasheet of the Allwinner H5 and noticed the functions of the pinning is totally different and there is no pwm1
https://linux-sunxi.org/images/a/a3/Allwinner_H5_Manual_v1.0.pdf
A second look at the schematics of the orange pi zero plus confronted me with the fact they did not replaced the chip and have just used the H3 chip in the schematics.
https://drive.google.com/drive/folders/1RH2j3TY7MUZvV9V_cz6r5iDbeloxnEy6
Using pwm on this board is not usable for me, as I do not want to disable the ttyS0.
As it is only for driving a buzzer I will probably replace the buzzer for an active buzzer.
So solved: Documentation of board is misleading..
Share this post
Link to post
1 1
