hostmaster Posted July 13, 2020 Posted July 13, 2020 (edited) The reason MX Linux performed so well is, because, it uses some core components from Antix Linux Distro, which is optimised.based on Debian's "stable" branch. MX Linux is a cooperative venture between the antiX and former MEPIS communities, using the best tools and talents from each distro. It is a midweight OS designed to combine an elegant and efficient desktop with simple configuration, high stability, solid performance and medium-sized footprint. Edited July 13, 2020 by hostmaster
sfx2000 Posted August 23, 2020 Posted August 23, 2020 On 7/13/2020 at 11:59 AM, hostmaster said: The reason MX Linux performed so well is, because, it uses some core components from Antix Linux Distro, which is optimised. based on Debian's "stable" branch. To support MX - one would have the rip out the systemd guts, and reimplement everything that systemd does...
Tido Posted August 24, 2020 Posted August 24, 2020 On 7/13/2020 at 8:59 PM, hostmaster said: MX Linux performed so well IIRC it is based on XFCE, just like armbian Desktop. So, you can change the look and your MX is done Apart from that, you remind me about him: https://forum.armbian.com/topic/14645-lnoodle/?
