Hello guys,
I have a NOVAsom M7+ board with a RTL8723bs module with Wi-Fi and Bluetooth integrated. The Wi-Fi works normally and without problems, however the Bluetooth isn't detected at all. When I try to open the Bluetooth Manager app gives me this error: "Connection to BlueZ failed. BlueZ daemon is not running. blueman-manager cannot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started".
I already searched the internet and found some people with problems related to this module and Bluetooth, does anyone know how to solve this?
Best regards
Hard to tell without further information. What image are you using?
armbianmonitor -u
armbianmonitor -u
I'm using Debian GNU/Linux 10 with 4.4.167 kernel..
When I made the "dmesg | grep -i 8723 it shows the Bluetooth interface but when I try to open the Bluetooth Manager says the "Connection to BlueZ failed"..
And when I made the "sudo rfkill list" it shows me only this two:
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: phy1: Wireless LAN
    Soft blocked: no
    Hard blocked: no
