I am running Armbian Focal with Linux 5.4.43-sunxi64 (and now downgraded to 4.19.125-sunxi64) on my Orange Pi PC 2. I use motion software to provide a "18ec:5555 Arkmicro Technologies Inc. USB2.0 PC CAMERA" to the network. I also use pjsip to provide SIP functionality for the same device as audio input. As soon as I start pjsip for some reason I get a very high load average until the kernel detectets stalled CPUs and finally the entire device crashes. This worked fine in a previous version and started after I upgraded to focal. I did a kernel backtrace and this is what I got:
[  401.002517] sysrq: Show backtrace of all active CPUs
[  401.009965] sysrq: CPU1:
[  401.010084] Call trace:
[  401.010394]  dump_backtrace+0x0/0x180
[  401.010573]  show_stack+0x14/0x20
[  401.010811]  showacpu+0x94/0xc8
[  401.011039]  flush_smp_call_function_queue+0x90/0x150
[  401.011247]  generic_smp_call_function_single_interrupt+0x10/0x18
[  401.011471]  handle_IPI+0xf8/0x180
[  401.011634]  gic_handle_irq+0x9c/0xa0
[  401.011806]  el0_irq_naked+0x4c/0x54
[  401.011993] sysrq: CPU3:
[  401.012118] Call trace:
[  401.012372]  dump_backtrace+0x0/0x180
[  401.012533]  show_stack+0x14/0x20
[  401.012743]  showacpu+0x94/0xc8
[  401.012939]  flush_smp_call_function_queue+0x90/0x150
[  401.013137]  generic_smp_call_function_single_interrupt+0x10/0x18
[  401.013346]  handle_IPI+0xf8/0x180
[  401.013506]  gic_handle_irq+0x9c/0xa0
[  401.013675]  el0_irq_naked+0x4c/0x54
[  401.013834] sysrq: CPU0:
[  401.013941] Call trace:
[  401.014159]  dump_backtrace+0x0/0x180
[  401.014342]  show_stack+0x14/0x20
[  401.014548]  showacpu+0x94/0xc8
[  401.014937]  flush_smp_call_function_queue+0x90/0x150
[  401.015139]  generic_smp_call_function_single_interrupt+0x10/0x18
[  401.015345]  handle_IPI+0xf8/0x180
[  401.015501]  gic_handle_irq+0x9c/0xa0
[  401.015657]  el1_irq+0xb8/0x140
[  401.015915]  arch_counter_get_cntpct+0x8/0x18
[  401.016143]  ktime_get+0x40/0xa0
[  401.016633]  uvc_video_decode_start+0x6d8/0x7e8 [uvcvideo]
[  401.017006]  uvc_video_decode_isoc+0xac/0x168 [uvcvideo]
[  401.017359]  uvc_video_complete+0x11c/0x1c8 [uvcvideo]
[  401.017613]  __usb_hcd_giveback_urb+0x70/0x130
[  401.017821]  usb_giveback_urb_bh+0xf0/0x190
[  401.018030]  tasklet_action_common.isra.19+0xc4/0x188
[  401.018182]  tasklet_hi_action+0x24/0x30
[  401.018349]  __do_softirq+0x11c/0x230
[  401.018497]  irq_exit+0x9c/0xb8
[  401.018750]  __handle_domain_irq+0x64/0xb8
[  401.018904]  gic_handle_irq+0x50/0xa0
[  401.019058]  el1_irq+0xb8/0x140
[  401.019279]  clk_core_unprepare+0x0/0x100
[  401.019529]  clk_core_set_rate_nolock+0x1bc/0x1e8
[  401.019725]  clk_set_rate+0x34/0xa0
[  401.019962]  dev_pm_opp_set_rate+0x394/0x4f0
[  401.020230]  set_target+0x3c/0x80 [cpufreq_dt]
[  401.020428]  __cpufreq_driver_target+0x2bc/0x678
[  401.020611]  od_dbs_update+0xb8/0x190
[  401.020801]  dbs_work_handler+0x3c/0x70
[  401.021027]  process_one_work+0x1ec/0x370
[  401.021218]  worker_thread+0x4c/0x4f8
[  401.021401]  kthread+0x120/0x128
[  401.021601]  ret_from_fork+0x10/0x18
[  403.369173] sysrq: Show backtrace of all active CPUs
[  403.375878] sysrq: CPU0:
[  403.375993] Call trace:
[  403.376316]  dump_backtrace+0x0/0x180
[  403.376496]  show_stack+0x14/0x20
[  403.376721]  showacpu+0x94/0xc8
[  403.376942]  flush_smp_call_function_queue+0x90/0x150
[  403.377146]  generic_smp_call_function_single_interrupt+0x10/0x18
[  403.377354]  handle_IPI+0xf8/0x180
[  403.377667]  gic_handle_irq+0x9c/0xa0
[  403.378019]  el1_irq+0xb8/0x140
[  403.378650]  uvc_video_decode_start+0x104/0x7e8 [uvcvideo]
[  403.379181]  uvc_video_decode_isoc+0xac/0x168 [uvcvideo]
[  403.379899]  uvc_video_complete+0x11c/0x1c8 [uvcvideo]
[  403.380312]  __usb_hcd_giveback_urb+0x70/0x130
[  403.380606]  usb_giveback_urb_bh+0xf0/0x190
[  403.380793]  tasklet_action_common.isra.19+0xc4/0x188
[  403.380945]  tasklet_hi_action+0x24/0x30
[  403.381110]  __do_softirq+0x11c/0x230
[  403.381460]  irq_exit+0x9c/0xb8
[  403.381862]  __handle_domain_irq+0x64/0xb8
[  403.382180]  gic_handle_irq+0x50/0xa0
[  403.382497]  el1_irq+0xb8/0x140
[  403.382876]  tcp_sendmsg_locked+0x288/0xc90
[  403.383202]  tcp_sendmsg+0x34/0x58
[  403.383488]  inet_sendmsg+0x40/0x68
[  403.383686]  sock_sendmsg+0x44/0x50
[  403.383869]  __sys_sendto+0xcc/0x130
[  403.384033]  __arm64_sys_sendto+0x24/0x30
[  403.384273]  el0_svc_common.constprop.2+0x88/0x150
[  403.384476]  el0_svc_handler+0x20/0x80
[  403.384636]  el0_svc+0x8/0xc
[  403.384802] sysrq: CPU1:
[  403.384917] Call trace:
[  403.385150]  dump_backtrace+0x0/0x180
[  403.385323]  show_stack+0x14/0x20
[  403.385535]  showacpu+0x94/0xc8
[  403.385747]  flush_smp_call_function_queue+0x90/0x150
[  403.385950]  generic_smp_call_function_single_interrupt+0x10/0x18
[  403.386152]  handle_IPI+0xf8/0x180
[  403.386306]  gic_handle_irq+0x9c/0xa0
[  403.386477]  el0_irq_naked+0x4c/0x54
[  406.143125] sysrq: Show backtrace of all active CPUs
[  406.158279] sysrq: CPU2:
[  406.158407] Call trace:
[  406.158720]  dump_backtrace+0x0/0x180
[  406.158892]  show_stack+0x14/0x20
[  406.159119]  showacpu+0x94/0xc8
[  406.159340]  flush_smp_call_function_queue+0x90/0x150
[  406.159544]  generic_smp_call_function_single_interrupt+0x10/0x18
[  406.159763]  handle_IPI+0xf8/0x180
[  406.159931]  gic_handle_irq+0x9c/0xa0
[  406.160097]  el1_irq+0xb8/0x140
[  406.160303]  __seccomp_filter+0x74/0x5e8
[  406.160484]  __secure_computing+0x38/0xc0
[  406.160701]  syscall_trace_enter+0x100/0x148
[  406.160925]  el0_svc_common.constprop.2+0x54/0x150
[  406.161125]  el0_svc_handler+0x20/0x80
[  406.161282]  el0_svc+0x8/0xc
[  406.161441] sysrq: CPU1:
[  406.161550] Call trace:
[  406.161773]  dump_backtrace+0x0/0x180
[  406.161949]  show_stack+0x14/0x20
[  406.162157]  showacpu+0x94/0xc8
[  406.162349]  flush_smp_call_function_queue+0x90/0x150
[  406.162711]  generic_smp_call_function_single_interrupt+0x10/0x18
[  406.162916]  handle_IPI+0xf8/0x180
[  406.163076]  gic_handle_irq+0x9c/0xa0
[  406.163240]  el0_irq_naked+0x4c/0x54
[  406.163399] sysrq: CPU0:
[  406.163511] Call trace:
[  406.163729]  dump_backtrace+0x0/0x180
[  406.163906]  show_stack+0x14/0x20
[  406.164110]  showacpu+0x94/0xc8
[  406.164311]  flush_smp_call_function_queue+0x90/0x150
[  406.164507]  generic_smp_call_function_single_interrupt+0x10/0x18
[  406.164710]  handle_IPI+0xf8/0x180
[  406.164871]  gic_handle_irq+0x9c/0xa0
[  406.165026]  el1_irq+0xb8/0x140
[  406.165610]  uvc_video_decode_start+0x3d8/0x7e8 [uvcvideo]
[  406.166155]  uvc_video_decode_isoc+0xac/0x168 [uvcvideo]
[  406.166672]  uvc_video_complete+0x11c/0x1c8 [uvcvideo]
[  406.167086]  __usb_hcd_giveback_urb+0x70/0x130
[  406.167451]  usb_giveback_urb_bh+0xf0/0x190
[  406.167804]  tasklet_action_common.isra.19+0xc4/0x188
[  406.168128]  tasklet_hi_action+0x24/0x30
[  406.168458]  __do_softirq+0x11c/0x230
[  406.168691]  irq_exit+0x9c/0xb8
[  406.168922]  __handle_domain_irq+0x64/0xb8
[  406.169071]  gic_handle_irq+0x50/0xa0
[  406.169396]  el1_irq+0xb8/0x140
[  406.169755]  tcp_sendmsg_locked+0x288/0xc90
[  406.170081]  tcp_sendmsg+0x34/0x58
[  406.170441]  inet_sendmsg+0x40/0x68
[  406.170783]  sock_sendmsg+0x44/0x50
[  406.171117]  __sys_sendto+0xcc/0x130
[  406.171444]  __arm64_sys_sendto+0x24/0x30
[  406.171842]  el0_svc_common.constprop.2+0x88/0x150
[  406.172216]  el0_svc_handler+0x20/0x80
[  406.172541]  el0_svc+0x8/0xc
[  408.204456] sysrq: Show backtrace of all active CPUs
[  408.214175] sysrq: CPU1:
[  408.214296] Call trace:
[  408.214624]  dump_backtrace+0x0/0x180
[  408.214813]  show_stack+0x14/0x20
[  408.215046]  showacpu+0x94/0xc8
[  408.215271]  flush_smp_call_function_queue+0x90/0x150
[  408.215477]  generic_smp_call_function_single_interrupt+0x10/0x18
[  408.215870]  handle_IPI+0xf8/0x180
[  408.216039]  gic_handle_irq+0x9c/0xa0
[  408.216216]  el0_irq_naked+0x4c/0x54
[  408.216351] sysrq: CPU2:
[  408.216453] Call trace:
[  408.216675]  dump_backtrace+0x0/0x180
[  408.216843]  show_stack+0x14/0x20
[  408.217054]  showacpu+0x94/0xc8
[  408.217250]  flush_smp_call_function_queue+0x90/0x150
[  408.217456]  generic_smp_call_function_single_interrupt+0x10/0x18
[  408.217666]  handle_IPI+0xf8/0x180
[  408.217824]  gic_handle_irq+0x9c/0xa0
[  408.217985]  el1_irq+0xb8/0x140
[  408.218219]  kmsg_read+0x50/0x60
[  408.218440]  proc_reg_read+0x5c/0xc8
[  408.218632]  __vfs_read+0x18/0x40
[  408.218802]  vfs_read+0x9c/0x188
[  408.218968]  ksys_read+0x64/0xe8
[  408.219142]  __arm64_sys_read+0x18/0x20
[  408.219375]  el0_svc_common.constprop.2+0x88/0x150
[  408.219581]  el0_svc_handler+0x20/0x80
[  408.219739]  el0_svc+0x8/0xc
[  408.219893] sysrq: CPU0:
[  408.219995] Call trace:
[  408.220206]  dump_backtrace+0x0/0x180
[  408.220376]  show_stack+0x14/0x20
[  408.220588]  showacpu+0x94/0xc8
[  408.220782]  flush_smp_call_function_queue+0x90/0x150
[  408.220981]  generic_smp_call_function_single_interrupt+0x10/0x18
[  408.221184]  handle_IPI+0xf8/0x180
[  408.221336]  gic_handle_irq+0x9c/0xa0
[  408.221490]  el1_irq+0xb8/0x140
[  408.221688]  arch_local_irq_restore+0x4/0x10
[  408.221925]  usb_hcd_submit_urb+0xdc/0xad0
[  408.222133]  usb_submit_urb+0x1e0/0x580
[  408.222619]  uvc_video_complete+0x188/0x1c8 [uvcvideo]
[  408.222971]  __usb_hcd_giveback_urb+0x70/0x130
[  408.223348]  usb_giveback_urb_bh+0xf0/0x190
[  408.223700]  tasklet_action_common.isra.19+0xc4/0x188
[  408.224029]  tasklet_hi_action+0x24/0x30
[  408.224350]  __do_softirq+0x11c/0x230
[  408.224589]  irq_exit+0x9c/0xb8
[  408.224822]  __handle_domain_irq+0x64/0xb8
[  408.224972]  gic_handle_irq+0x50/0xa0
[  408.225299]  el1_irq+0xb8/0x140
[  408.225673]  tcp_sendmsg_locked+0x288/0xc90
[  408.226005]  tcp_sendmsg+0x34/0x58
[  408.226364]  inet_sendmsg+0x40/0x68
[  408.226717]  sock_sendmsg+0x44/0x50
[  408.227058]  __sys_sendto+0xcc/0x130
[  408.227391]  __arm64_sys_sendto+0x24/0x30
[  408.227782]  el0_svc_common.constprop.2+0x88/0x150
[  408.228153]  el0_svc_handler+0x20/0x80
[  408.228465]  el0_svc+0x8/0xc
Does anybody know what might be going on here and how I can fix this issue? Or do I need to go back to Ubuntu Bionic with Armbian Linux 4.13.2-sun50iw2 which I was running before?
Sure, I had to remove some sensitive information like IPv6 Addresses and NFS Paths though.
Expand
No worries. Guess the information collection needs to be enhanced there... (feel free to contribute :P)
Expand
Not sure if I got that right. It does work in 4.13.x but also does in legacy branch 4.19.x?
It does not work in the legacy branch, it just used to work on 4.13.x before I upgraded to focal (I think I was on bionic before but I need to check that again). I tried the legacy branch as I was hoping that it could be better, but unfortunately it isn't.
