[  OK  ] Finished Set console font and keymap.
[  OK  ] Finished Helper to synchronize boot up for ifupdown.
         Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Found device /dev/ttyGS0.
[   14.547006] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22
I just installed Armbian Focal on my Orange Pi Zero and i receive this error on startup, then the boot stops here.
It did pass this step a couple times but 90% of the time it will not boot.
Thanks in advance,
//Hasan
44 minutes ago, Werner said:
Where did you get the log from? Do you have a serial console on it?
I have it connected to my laptop via TTL.
For some weird reason I cannot post more than once per day. So hope you see this edit...
It's the current (latest) version of the Armbian Focal.
Edited by peytuk
Sorry for my English, I use a translator..
I have had the same error report, however if the operating system starts me, but the temperatures of the orange pi zero LTS with the H2+ are very low, they are erroneous measurements, does anyone know how I can solve this problem
[   11.042639] kernel: zram: Added device: zram0
[   11.045370] kernel: zram: Added device: zram1
[   11.048901] kernel: zram: Added device: zram2
[   11.229264] kernel: core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[   11.229304] kernel: cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
[   11.229547] kernel: core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[   11.229567] kernel: cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
[   11.229808] kernel: core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
[   11.229831] kernel: cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
[   11.230071] kernel: core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
[   11.230092] kernel: cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
[   11.231038] kernel: thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22
[   11.322014] kernel: zram0: detected capacity change from 0 to 257781760
[   11.601861] systemd[1]: Found device /dev/ttyS0.
[   11.743540] kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   11.749298] kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   11.869109] kernel: rtl8188fu: loading out-of-tree module taints kernel.
[   11.967820] kernel: rtl8188fu: module verification failed: signature and/or required key missing - tainting kernel
[   11.996768] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.998115] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.999138] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.999670] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   12.000082] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   12.000381] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
what does this error mean and if it has any correlation with having very low temperatures in the orange pi zero LTS
  >  thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
03:37:18: 1008MHz  0.04   1%   1%   0%   0%   0%   0%  5.3°C  0/4
03:37:23: 1008MHz  0.03   2%   1%   0%   0%   0%   0%  5.1°C  0/4
03:37:28:  480MHz  0.03   2%   1%   0%   0%   0%   0%  4.6°C  0/4
03:37:34: 1008MHz  0.03   2%   2%   0%   0%   0%   0%  5.8°C  0/4
03:37:39:  480MHz  0.03   2%   1%   0%   0%   0%   0%  4.1°C  0/4
this is my armbian version..
root@orangepizero:~# uname -a
Linux orangepizero 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l armv7l armv7l GNU/Linux
