Greetings,
   I'm attempting to apply a custom patch during the build process for a bananapi-m2-zero. (specifically, DTS changes)    I went into the kernel source, and created a diff, and put it in the user customized patches directory.  Unfortunately, the patch failed.  So, I dug into it, and discovered the source changes because of patches in the armbian patches/ directory.  So, instead I started the build, let these patches apply,, and aborted the build. Then I created the diff again.  Sadly, the patch is still being rejected.
Now, I might be able to fight with this, and make it work.  But the next time I pull a new update it could be broken and I have to go through this again.
So, is there any way I can make this work?
On 7/29/2020 at 2:01 AM, Werner said:
How did you make the custom patch? Did you use the CREATE_PATCHES flag?
Well, I took the original source code, from the linux kernel tree.
I modified it, and then created the diff.
That did not work, so I built armbian, and let all the patches do their things.
Then I took the fully patched file (from the build) made my chanbges, and created a diff.
I put that diff in userpatches.  I was able to get this to work by forcing it to patch last, by prefixing the file name with 'zzz'.
I wasn't aware of CREATE_PATCHES, but that is great. I will try that
