I’m running Armbian 20.05.7 stable on an Odroid HC2 (XU4). I installed Docker Compose using the instrux found in the Linux section of the Docker install page.
I’m logged in as root via SSH. I run the curl command (which I literally copied/pasted from the docs install page)
curl -L "https://github.com/docker/compose/releases/download/1.26.2/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
then
chmod +x /usr/local/bin/docker-compose
and I check it with
which docker-compose
which returns:
When I try to test the installation…
docker-compose --version
it returns:
bash: /usr/bin/docker-compose: Permission denied
Notice that it seems to want /usr/bin instead of /usr/local/bin, so (as suggested on the docs install page) I run
ln -s /usr/local/bin/docker-compose /usr/bin/docker-compose
and I try to test the installation again. Now it returns:
/usr/bin/docker-compose: line 1: Not: command not found
I removed everything and tried the curl command (pointed at /usr/bin instead of /usr/local/bin) again, followed by the chmod command. Now which docker-compose returns
So I try to test the installation again with docker-compose --version and I get the same thing:
What in the heck am I doing wrong? I tried posting this on the Docker forums but no one has responded so I'm wondering if it's more of an Armbian issue.
On a user space level its almost 99% chances that its not an Armbian issue. It can be yet another GNU software bug. "1000 people's" work we don't even try to fix or problem with a software you are trying to install.
As you can see, ARM architecture is not available as binary. You will need to build from sources.
In case anyone stumbles upon this and, like me, is trying to install docker-compose on Debian Buster-based Armbian (arm64 architecture) the answer, as it turns out, is quite simple...
Install Docker using softy. (Softy does all the work - it's great!) I recommend testing the install with
docker run hello-world
Once that's done and successful, you can just run
sudo apt install docker-compose
and it just works. If you want to test it, paste this into docker-compose.yml:
version: '3'
services:
  web:
    image: nginx:latest
    ports:
     - "8080:80"
    links:
     - php
  php:
    image: php:7-fpm
then run
docker-compose up -d && docker ps
Many thanks to you ErnieePantuso. I am a beginner that confronted this very issue, and your solution was so appreciated. Just for the record, I am a noob, now successful in installing:
Armbian 23.8.1 Jammy Current 6.1.5.0 and after update and upgrade, arrived at Armbian 23.11.1 on 6.1.5.0 on a S905X3  android box (A95XF3 Air). I had problems finding a u-boot.ext that would work, and the two different Armbian sites made it a little confusing since they use different install techniques. I know this thread is old, but still useful.
