Armbianmonitor:
When I try to read the input on PA19 immediately goes to "1" even though there is no voltage being sent to the pin.
Example:
#!/usr/local/bin/python
from pyA20.gpio import gpio
from pyA20.gpio import port
pin_to_circuit = port.PA19
gpio.init()
gpio.setcfg(pin_to_circuit, gpio.OUTPUT)
gpio.output(pin_to_circuit, 0)
gpio.setcfg(pin_to_circuit, gpio.INPUT)
print(gpio.input(pin_to_circuit))
I don't understand why this would put "1" with nothing even connected to the PA19 pin?
Are there some settings I need to change to get PA19 working as a normal GPIO pin?
Pretty normal : PA19 is shared also as TWI1-SDA which is an I2C bus provided on header, and there are some PullUps resistors already present on the OPiZero board.
So, simply short PA19 to GND, you will see that your script will print "0".
14 hours ago, David12412412 said:
If i short PA19 to GND how will I detect any input on PA19 as it will always just show "0"?
I didn't say to short to GND permanently, but simply to check that the input is working fine as normal GPIO ...
Is there any way to disable TWI1-SDA
It is already disabled by default, unless you load an I2C DT overlay ...
I'm still not really understanding how I go about using PA19 as a normal GPIO input port, so that I can check if an input has been received (such as from a push button).
Shorting PA19 to GND just means the voltage goes straight to GND and doesn't get detected as an INPUT.
I'm not sure if I'm asking my question in the wrong way?
For example if I have a push button from 3.3V to PA19 how can I detect a push on the button?
Circuit like this:
3.3V --------> Push Button ------->1k Resistor ------> PA19
Currently I cannot detect a push on this circuit because PA19 just shows "1" all the time for the input.
Edited by David12412412
Error prone HW design with floating IO.
Proper design with fixed IO states:
VCC --------> Pullup Resistor ---|
GND --------> Push Button -------+------> PA19
The pullup is already in place.
Pressing the button will flip the IO from 1 to 0.
15 hours ago, Gabriel Bastos said:
Have u managed to PA19 work as input without reading HIGH level ?
What do you mean by "without reading HIGH level" ?
PA19 has a PullUp resistor, so by default it will be read as HIGH. To read it as LOW, it need to be shorted to GND as mentioned earlier in this thread ...
