I've built Armbian for my purposes with the following build settings:
./compile.sh BOARD="bananapi" BRANCH="current" RELEASE="focal" \
            KERNEL_ONLY="no" KERNEL_CONFIGURE="no" BUILD_DESKTOP="no" EXTERNAL="yes" \
            INSTALL_HEADERS="yes"
.. and the board boots from the resulting image just fine, and seems to be running well.
Now, I want to clone a repo onto this board, and use the ONBOARD compiler for development purposes .. I'm doing some CAN development, and I want to use SocketCan (https://github.com/jackthompsonnz/socketcan-linux-5.0.git) which is a kernel module for gaining access to a USB-CAN adapter.
So I connect to it, clone the SocketCan Repo and get a message like this:
mcp@mcp:~/CANDevelopment/third/socketcan-linux-5.0$ make
make -C /lib/modules/5.7.11-sunxi/build M=/home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan modules
make[1]: Entering directory '/usr/src/linux-headers-5.7.11-sunxi'
  CC [M]  /home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan/ixx_usb_v2.o
In file included from /home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan/ixx_usb_v2.c:32:
/home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan/ixx_usb_core.h:196:24: error: field ‘tv_host_0’ has incomplete type
  196 |         struct timeval tv_host_0;
make[2]: *** [scripts/Makefile.build:267: /home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan/ixx_usb_v2.o] Error 1
make[1]: *** [Makefile:1734: /home/mcp/CANDevelopment/third/socketcan-linux-5.0/usb-to-can_socketcan] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.7.11-sunxi'
make: *** [Makefile:4: ixx_usb] Error 2
.. which implies that the compiler (onboard) is not using its own sysroot in order to pick up the basic types (such as is in sys/time.h) .. so I add "-isystem /usr/include/arm-linux-gnueabihf/sys" to the flags, and things build again ..
The question is, how do I 'properly' tell Armbian's build process to include the right sysroot configuration in the compiler by default - I don't really want to have to add the -isystem flag to every repo I clone for building on this board - there has to be some missing step in the setup of the Armbian build image to result in this compiler not being functional .. perhaps I missed a step?
FWIW, I verified that the linux-headers package for my board (sunxi - bananapi) is installed, and works .. and if I add '-isystem /usr/include/arm-linux-gnueabihf/sys' to everything the compiler seems to function just fine.
Did I skip a missing "link files" step somewhere, or anyone got any other clues?  Where possible I'd like to use Armbian with as few 'hacks/fixups' as possible, and maybe this is just me missing something obvious in the build setup ..
