guidol Posted August 13, 2020 Posted August 13, 2020 It seems that the actual install routine of Pihole doenst detect buster with kernel 5.8 correctly. At "my" normal install command "curl -sSL https://install.pi-hole.net | bash" I did get [✗] Unsupported OS detected: Armbian 20.08.0-trunk Buster https://docs.pi-hole.net/main/prerequesites/#supported-operating-systems e.g: If you are seeing this message on a fresh install, you can run: 'curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash' If you are seeing this message after having run pihole -up: 'PIHOLE_SKIP_OS_CHECK=true sudo -E pihole -r' (In this case, your previous run of pihole -up will have already updated the local repository) but after giving (as written above) the install command with the option "to not check the OS" curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash the installation went fine 1
guidol Posted August 12, 2021 Author Posted August 12, 2021 As Hirsute Hippo is at this time also a unsupported OS - there is another catch to get the lighthttpd of pihole working with the Hippo While using the PIHOLE_SKIP_OS_CHECK=true the install-routine cant restart the lighthttpd correctly, because the package lighttpd-mod-deflate is missing When the install routine does try to restart the lighthttpd it fails with: journalctl -u lighttpd configfile.c.461) Warning: "mod_compress" is DEPRECATED and has been replaced with "mod_deflate". A future release of lighttpd 1.4.x will not contain mod_compresss and lighttpd may fail to start up plugin.c.195) dlopen() failed for: /usr/lib/lighttpd/mod_deflate.so /usr/lib/lighttpd/mod_deflate.so: cannot open shared object file: No such file or directory server.c.1238) loading plugins finally failed The Hippo has no mod_compress in the lighthttpd but its searching for the replacement mod_deflate mod_deflate can be installed via apt install lighttpd-mod-deflate While there were also other requirements missing on new installs of pihole I did use the following install-command: apt install php-cgi php-common php php-sqlite3 dhcpcd5 lighttpd-mod-deflate -y && curl -sSL https://install.pi-hole.net | PIHOLE_SKIP_OS_CHECK=true sudo -E bash As a "goodie" you can edit after the installation od pihole the /etc/lighttpd/lighttpd.conf and do the follwoing replacement: change line "mod_compress", against "mod_deflate", then save/exit and restart lighthttpd with /etc/init.d/lighttpd restart This way I got pihole running under Hirsute Hippo 1
Helmut Posted August 13, 2021 Posted August 13, 2021 I installed Pihole on Buster with kernel 5.10 (on Odroid N2) a while ago. I don't think I encountered issues with the installation command. It is also an option to use Pihole with an installed apache web server. This has been working fine for me.
guidol Posted August 13, 2021 Author Posted August 13, 2021 21 minutes ago, Helmut said: I installed Pihole on Buster with kernel 5.10 (on Odroid N2) a while ago. I don't think I encountered issues with the installation command. I had also some installations in the past with buster and no install problems...but with every new OS version there could be a problem. We also woud see how it would work with bullseye (after buster)
guidol Posted August 14, 2021 Author Posted August 14, 2021 23 hours ago, guidol said: We also woud see how it would work with bullseye (after buster) bullseye with kernel 5.13.10 also did need the packet lighttpd-mod-deflate for installing/running lighthttpd like the Hirsute Hippo Got it running here on my BPI-M1 with bullseye and kernel 5.13.10: Linux bpi-m1-120 5.13.10-sunxi #trunk.118 SMP Thu Aug 12 18:20:37 UTC 2021 armv7l GNU/Linux root@bpi-m1-120(192.168.6.120):~# dpkg -l|grep deflate ii lighttpd-mod-deflate 1.4.59-1 armhf HTTP response compression module for lighttpd
