DeterminedOpier Posted August 19, 2020 Share Posted August 19, 2020 Armbianmonitor: http://ix.io/2uAu Hi guys. I've just spent yet another two hours trying to find an answer to my webcam problem and there does not seem to be an answer from what I can discern. Still working to try to get a camera to work with Octopi from what I have around. Strange thing I discovered that the USB OTG port on the Opi One does not seem to work, but when plugged into my single regular USB, I get this for the camera: pi@citrico-opione:~/ffmpeg_cedrus264_H3$ lsusb Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 1908:2310 GEMBIRD Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub It is one of the known working with mjpeg-streamer https://community.octoprint.org/t/usb-webcams-known-to-work-with-mjpg-streamer/21149 but the notes don't seem to be current. pi@citrico-opione:~/ffmpeg_cedrus264_H3$ ls /dev/video* /dev/video0 /dev/video1 /dev/video2 I have tried some of the old gits out there. My only ray of hope was when I did modprobe hid-gembird it did not error, just seemed to say ok. But still no webcam, just a different message, of/dev/video0: Device or resource busy instead of it not being a video capture device. So I"m out of ideas. Any help would be appreciated. Trying to find an inexpensive webcam solution for octopi using my Opi Ones. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 19, 2020 Author Share Posted August 19, 2020 A few more details: pi@citrico-opione:~/ffmpeg_cedrus264_H3$ v4l2-ctl --list-devices cedrus (platform:cedrus): /dev/video2 USB2.0 PC CAMERA: USB2.0 PC CAM (usb-1c1b000.usb-1): /dev/video0 /dev/video1 pi@citrico-opione:~/ffmpeg_cedrus264_H3$ cd pi@citrico-opione:~$ v4l2-ctl --list-devices cedrus (platform:cedrus): /dev/ pi@citrico-opione:~$ v4l2-ctl -d /dev/video2 --list-formats --list-ctrls Codec Controls mpeg_2_slice_parameters 0x009909fa (unknown): type=103 flags=has-payload mpeg_2_quantization_matrices 0x009909fb (unknown): type=104 flags=has-payload h264_sequence_parameter_set 0x00990ce8 (unknown): type=110 flags=has-payload h264_picture_parameter_set 0x00990ce9 (unknown): type=111 flags=has-payload h264_scaling_matrix 0x00990cea (unknown): type=112 flags=has-payload h264_slice_parameters 0x00990ceb (unknown): type=113 flags=has-payload h264_decode_parameters 0x00990cec (unknown): type=114 flags=has-payload h264_decode_mode 0x00990ced (menu) : min=0 max=0 default=0 value=0 h264_start_code 0x00990cee (menu) : min=0 max=0 default=0 value=0 hevc_sequence_parameter_set 0x00990cf0 (unknown): type=120 flags=has-payload hevc_picture_parameter_set 0x00990cf1 (unknown): type=121 flags=has-payload hevc_slice_parameters 0x00990cf2 (unknown): type=122 flags=has-payload hevc_scaling_matrix 0x00990cf3 (unknown): type=123 flags=has-payload hevc_decode_mode 0x00990cf7 (menu) : min=0 max=0 default=0 value=0 hevc_start_code 0x00990cf8 (menu) : min=0 max=0 default=0 value=0 ioctl: VIDIOC_ENUM_FMT Type: Video Capture [0]: 'ST12' (Sunxi Tiled NV12 Format, compressed) [1]: 'NV12' (Y/CbCr 4:2:0) USB2.0 PC CAMERA: USB2.0 PC CAM (usb-1c1b000.usb-1): /dev/video0 /dev/video1 I'm still working on it. These commands I got from @ldiaz working on my rpi cameras that didn't work. It seems like the gembird is a common camera though, and it seems like it should be working, but so far it isn't. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 19, 2020 Author Share Posted August 19, 2020 And get this. The snapshot works in octoprint, which is listed as this: http://127.0.0.1:8080/?action=snapshot That was after I switched the ffmpeg path to: /home/pi/ffmpeg_cedrus264_H3/ffmpeg Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 20, 2020 Author Share Posted August 20, 2020 For those who may be finding this thread later, I made some interesting progress today. The Orange Pi One has only one regular USB port, which, using OctoPi, you need for the printer. But it does have also a USB OTG, which you may call Micro USB, and I have never used it for anything. Initially I plugged in the camera to that with an adapter, and got nothing on lsusb at all. After some digging, I found the way to cure this. You have to edit the dtb file in the /boot/ dtb/ directory for your board. All the supported boards are in there. Then you have to convert that binary dtb file into text, with a program called dtc. pi@citrico-opione:/boot/dtb$ sudo dtc -I dtb /boot/dtb/sun8i-h3-orangepi-one.dtb -O dts -o /boot/dtb/sun8i-h3-orangepi-one.dts that gives you the dts file, which you can open in nano. pi@citrico-opione:/boot/dtb$ sudo nano sun8i-h3-orangepi-one.dts Find the code block that has dr_mode in it. On this board it is usb@1c19000. Change the value to host instead of otb. Then control x, y, enter to save the file. Then you have to convert it back to binary. You can make a backup of your original binary file first if you want, then do this: pi@citrico-opione:/boot/dtb$ sudo dtc -I dts /boot/dtb/sun8i-h3-orangepi-one.dts -O dtb -o /boot/dtb/sun8i-h3-orangepi-one.dtb then reboot. The micro usb is now a regular usb, and my gembird camera came up under lsusb. I also had enabled usb0 in the hardware options in armbian-config, but I don't know if I had to do that. I actually just enabled them all before finding this solution. Still stuck on the video though. Snapshots are working. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 24, 2020 Author Share Posted August 24, 2020 I have made the change on several of these Orange Pi Ones now, and you don't have to do anything in armbian-config. Just that one field in the dtb file is it. Link to comment Share on other sites More sharing options...
ldiaz Posted August 29, 2020 Share Posted August 29, 2020 I think there is an overlay to activate usbhost modes https://github.com/armbian/sunxi-DT-overlays/tree/master/sun8i-h3 Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 30, 2020 Author Share Posted August 30, 2020 I don't know what that means lol, but I will try to figure it out when I return to the Opi attempt at octoprint. Thankyou. Link to comment Share on other sites More sharing options...
ldiaz Posted August 30, 2020 Share Posted August 30, 2020 Overlays are pieces of device tree configurations that can be activated and deactivated dynamically. Using overlays you do not need to recomplile the dts for your board every time. In armbian is quite simple to activate them simply add /boot/armbianEnv.txt overlay = usbhost0 ...<other overlays> and reboot. Link to comment Share on other sites More sharing options...
martinayotte Posted August 30, 2020 Share Posted August 30, 2020 1 hour ago, ldiaz said: overlay = should be : overlays= Link to comment Share on other sites More sharing options...
DeterminedOpier Posted August 30, 2020 Author Share Posted August 30, 2020 Wow ok thanks. Will try it. Link to comment Share on other sites More sharing options...
