I tried to isntall RPi-Monitor using "sudo armbianmonitor -r".
It fails to install (service is not created). Install logs:
Installing RPi-Monitor. This can take up to 5 minutes. Be patient pleaseE: Unable to locate package rpimonitor
/usr/bin/armbianmonitor: line 697: /usr/share/rpimonitor/scripts/updatePackagesStatus.pl: No such file or directory
Now patching RPi-Monitor to deal correctly with H3
Now you're able to enjoy RPi-Monitor at http://192.168.xxx.xxx:8888
I've uploaded logging to http://ix.io/2uCH (armbianmonitor -u)
I expect this to be a generic Focal issue, but if it's not, my board info:
OrangePi PC
Using latest Focal build: Welcome to Armbian Focal with Linux 5.4.45-sunxi
Armbian_20.05.4_Orangepipc_focal_current_5.4.45.img
If you need more information, let me know.
Expand
Its a generic Armbian Focal issue. This package is served from our repository, but it was simply never added there - for Focal, while it exits for Bionic. Its fixed, but it will take several days before it shows up since we are right in the middle of a major update ... A quick hack would be to edit /etc/apt/sources.list.d/armbian.list and change focal for bionic, update, install this package, change back to focal and run update again.
