sa_leinad Posted August 26, 2020 Posted August 26, 2020 Hi all, I bought a Orange Pi PC 2 a year or two back, loaded the Armbian image successfully and tweaked it until it was just right for my application. As this piece of hardware was going to live on a remote property, I bought another 2 Orange Pi PC 2 boards and some new SD cards with the intention of having 2 backups - one for development and the other as spare. I loaded these two up with the latest Armbian image and configured them as needed. These two work fine, even if I swap the SD card between these two pieces of hardware. However, when I try to put the SD card from the original Orange Pi PC 2 into one of the newer Orange Pi PC 2 it will not boot. I can see on the UART console that it is trying to start the kernel but just hangs. These are all the same hardware: They are all Orange Pi PC 2's and even the board revision printed in the silkscreen is the same. So it makes no sense why certain SD cards work for some hardware and not others. Can anyone think of why this might be happening? I am thinking I have missed something really simple, so please give me all the advice you can - even if it is really basic. Many thanks to you all in advance.
Werner Posted August 26, 2020 Posted August 26, 2020 On 8/26/2020 at 8:04 AM, sa_leinad said: trying to start the kernel but just hangs. Expand Increase boot verbosity to 7 and retry.
sa_leinad Posted August 31, 2020 Author Posted August 31, 2020 I increased boot verbosity to 7 and this is the output on my serial console: <\r><\n> U-Boot SPL 2018.11-armbian (Feb 08 2019 - 11:25:48 +0100)<\r><\n> DRAM: 1024 MiB<\r><\n> Trying to boot from MMC1<\r><\n>
Werner Posted August 31, 2020 Posted August 31, 2020 On 8/31/2020 at 3:48 PM, sa_leinad said: U-Boot SPL 2018.11-armbian Expand Do you have eMMC module or similar? on this board? Because Armbian current is using 2020.04 U-Boot at the moment...
sa_leinad Posted August 31, 2020 Author Posted August 31, 2020 (edited) There appears to be no provision for eMMC on the OrangePi PC2. Quote Because Armbian current is using 2020.04 U-Boot at the moment... Expand Yes this image is about 2 years old and only works on my older OrangePi PC2. The images that do work on my two newer OrangePi PC2 boards both are using 2019.10 U-Boot. Edited August 31, 2020 by sa_leinad Typo. Wrong board was written.
Werner Posted August 31, 2020 Posted August 31, 2020 Well then...no clue... This would only make sense of the board itself was altered but since it has even the same revision, don't know.
