What does the latest buster image and a webmin install in common? They both cause my RockPi4 to not boot from NVMe SSD
Title pretty much summs it up!
I had a few problems getting my RockPi 4 to boot anything from SSD, but I did mangage too by compiling the current buster branch as a minimal image.
I also created a thread on the radxa forum: https://forum.radxa.com/t/trouble-booting-armbian-from-nvme-ssd/4362
With the current image on the website (buster - server - 5.8.y) my bootlog looks like this:
    DDR Version 1.20 20190314
    In
    channel 0
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 1
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 0 training pass!
    channel 1 training pass!
    change freq to 400MHz 0,1
    channel 0
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x82
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 1
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    change freq to 800MHz 1,0
    Channel 0: LPDDR4,800MHz
    Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
    Channel 1: LPDDR4,800MHz
    256B stride
    ch 0 ddrconfig = 0x101, ddrsize = 0x2020
    ch 1 ddrconfig = 0x101, ddrsize = 0x2020
    pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
    OUT
    Boot1: 2018-06-26, version: 1.14
    CPUId = 0x0
    ChipType = 0x10, 220
    Spi_ChipId = b4018
    SpiBootInit:0
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    SdmmcInit=0 1
    StorageInit ok = 21718
    SecureMode = 0
    SecureInit ret = 0, SecureMode = 0
    GPT vendor signature is wrong
    LoadTrust Addr:0x1800
    No find bl30.bin
    No find bl32.bin
    Load uboot, ReadLba = 1000
    Load OK, addr=0x200000, size=0xef1d0
    RunBL31 0x10000
    NOTICE:  BL31: v1.3(debug):0e7a845
    NOTICE:  BL31: Built : 16:13:46, Apr 17 2019
    NOTICE:  BL31: Rockchip release version: v1.1
    INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
    INFO:    Using opteed sec cpu_context!
    INFO:    boot cpu mask: 0
    INFO:    plat_rockchip_pmu_init(1181): pd status 3e
    INFO:    BL31: Initializing runtime services
    WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
    ERROR:   Error initializing runtime service opteed_fast
    INFO:    BL31: Preparing for EL3 exit to normal world
    INFO:    Entry point address = 0x200000
    INFO:    SPSR = 0x3c9
    U-Boot 2017.09-2692-gdf20631bd8 (Apr 30 2020 - 05:02:13 +0000), Build: jenkins-linux-build-release-131
    Model: Radxa ROCK Pi 4B
    PreSerial: 2
    DRAM:  3.9 GiB
    Relocation Offset is: f5bdf000
    Sysmem: init
    I2c speed: 400000Hz
    PMIC:  RK808
    vdd-center init 950000 uV
    MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
    Using default environment
    ## Error: "rkimg_bootdev" not defined
    Bootdev: mmc 1
    MMC: no card present
    mmc_init: -123, time 0
    rockchip_get_bootdev: can't find dev_desc!
    [Vendor ERROR]:Invalid boot device type(0)
    rockchip_get_boot_mode: dev_desc is NULL!
    init_resource_list: dev_desc is NULL!
    Can't find file:logo.bmp
    failed to display uboot logo
    CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
    CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
      aplll 816000 KHz
      apllb 24000 KHz
      dpll 800000 KHz
      cpll 24000 KHz
      gpll 800000 KHz
      npll 600000 KHz
      vpll 24000 KHz
      aclk_perihp 133333 KHz
      hclk_perihp 66666 KHz
      pclk_perihp 33333 KHz
      aclk_perilp0 266666 KHz
      hclk_perilp0 88888 KHz
      pclk_perilp0 44444 KHz
      hclk_perilp1 100000 KHz
      pclk_perilp1 50000 KHz
    Net:   eth0: ethernet@fe300000
    Hit key to stop autoboot('CTRL+C'):  0
    => run bootcmd_nvme
    Device 0: RKPARM: Invalid parameter part table
    Vendor: 0x126f Rev: 42B4S8JA Prod: F946281766
                Type: Hard Disk
                Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
    ... is now current device
    Scanning nvme 0:1...
    3185 bytes read in 4 ms (777.3 KiB/s)
    ## Executing script at 00500000
    Boot script loaded from nvme 0
    174 bytes read in 4 ms (42 KiB/s)
    13315903 bytes read in 123 ms (103.2 MiB/s)
    27275776 bytes read in 236 ms (110.2 MiB/s)
    74352 bytes read in 14 ms (5.1 MiB/s)
    267 bytes read in 8 ms (32.2 KiB/s)
    Applying kernel provided DT overlay rockchip-pcie-gen2.dtbo
    2698 bytes read in 7 ms (376 KiB/s)
    Applying kernel provided DT fixup script (rockchip-fixup.scr)
    ## Executing script at 09000000
    ## Loading init Ramdisk from Legacy Image at 0a200000 ...
       Image Name:   uInitrd
       Data Size:    13315839 Bytes = 12.7 MiB
       Load Address: 00000000
       Entry Point:  00000000
       Verifying Checksum ... OK
    ## Flattened Device Tree blob at 08300000
       Booting using the fdt blob at 0x8300000
       reserving fdt memory region: addr=8300000 size=78000
       Loading Ramdisk to e9114000, end e9dc6eff ... OK
       Loading Device Tree to 00000000e9099000, end 00000000e9113fff ... OK
    Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
    Total: 76200.743 ms
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 5.8.6-rockchip64 (root@desktop) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.1 SMP PREEMPT Thu Sep 3 18:03:42 CEST 2020
    [    0.000000] Machine model: Radxa ROCK Pi 4B
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 128 MiB at 0x00000000f0000000
    [    0.000000] NUMA: No NUMA configuration found
    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
    [    0.000000] NUMA: NODE_DATA [mem 0xef7e2100-0xef7e3fff]
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
    [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.0 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.0
    [    0.000000] percpu: Embedded 32 pages/cpu s93528 r8192 d29352 u131072
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
    [    0.000000] Policy zone: DMA32
    [    0.000000] Kernel command line: root=UUID=99ff4446-5f76-4d84-a267-b20b35248e8f rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart= usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
    [    0.000000] Memory: 3742588K/4061184K available (14396K kernel code, 2060K rwdata, 5944K rodata, 4160K init, 574K bss, 187524K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Rude variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
    [    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
    [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @ead00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000000eaca0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000eacb0000
    [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
    [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
    [    0.000000] random: get_random_bytes called from start_kernel+0x674/0x83c with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000993] Console: colour dummy device 80x25
    [    0.001817] printk: console [tty1] enabled
    [    0.001936] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.001969] pid_max: default: 32768 minimum: 301
    [    0.002110] LSM: Security Framework initializing
    [    0.002155] Yama: becoming mindful.
    [    0.002279] AppArmor: AppArmor initialized
    [    0.002364] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.002405] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.004901] rcu: Hierarchical SRCU implementation.
    [    0.007095] Platform MSI: interrupt-controller@fee20000 domain created
    [    0.007522] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
    [    0.009197] EFI services will not be available.
    [    0.009751] smp: Bringing up secondary CPUs ...
    [    0.010483] Detected VIPT I-cache on CPU1
    [    0.010521] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
    [    0.010537] GICv3: CPU1: using allocated LPI pending table @0x00000000eacc0000
    [    0.010586] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.011407] Detected VIPT I-cache on CPU2
    [    0.011433] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
    [    0.011445] GICv3: CPU2: using allocated LPI pending table @0x00000000eacd0000
    [    0.011476] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.012310] Detected VIPT I-cache on CPU3
    [    0.012335] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
    [    0.012347] GICv3: CPU3: using allocated LPI pending table @0x00000000eace0000
    [    0.012377] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.015951] CPU features: detected: EL2 vector hardening
    [    0.016341] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
    [    0.016630] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.016980] Detected PIPT I-cache on CPU4
    [    0.018344] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
    [    0.018827] GICv3: CPU4: using allocated LPI pending table @0x00000000eacf0000
    [    0.020208] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
    [    0.030680] Detected PIPT I-cache on CPU5
    [    0.032000] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
    [    0.032466] GICv3: CPU5: using allocated LPI pending table @0x00000000ead80000
    [    0.033703] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
    [    0.040230] smp: Brought up 1 node, 6 CPUs
    [    0.040613] SMP: Total of 6 processors activated.
    [    0.040660] CPU features: detected: 32-bit EL0 Support
    [    0.040690] CPU features: detected: CRC32 instructions
    [    0.040708] CPU features: detected: 32-bit EL1 Support
    [    0.264863] CPU: All CPU(s) started at EL2
    [    0.266043] alternatives: patching kernel code
    [    0.271924] devtmpfs: initialized
    [    0.291099] Registered cp15_barrier emulation handler
    [    0.291493] Registered setend emulation handler
    [    0.292578] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.292680] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.298528] xor: measuring software checksum speed
    [    0.339431]    8regs     :  1613.000 MB/sec
    [    0.379630]    32regs    :  1851.000 MB/sec
    [    0.419877]    arm64_neon:  1404.000 MB/sec
    [    0.419895] xor: using function: 32regs (1851.000 MB/sec)
    [  s
    [    1.354184] raid6: int64x4  xor()   571 MB/s
    [    1.422594] raid6: int64x2  gen()   964 MB/s
    [    1.490999] raid6: int64x2  xor()   498 MB/s
    [    1.559439] raid6: int64x1  gen()   718 MB/s
    [    1.627854] raid6: int64x1  xor()   381 MB/s
    [    1.627872] raid6: using algorithm neonx4 gen() 1458 MB/s
    [    1.627889] raid6: .... xor() 1051 MB/s, rmw enabled
    [    1.627906] raid6: using neon recovery algorithm
    [    1.629818] vcc5v0_sys: supplied by vcc12v_dcin
    [    1.630906] vcc3v3_pcie: supplied by vcc5v0_sys
    [    1.631324] vcc3v3_sys: supplied by vcc5v0_sys
    [    1.631905] vcc5v0_host: supplied by vcc5v0_sys
    [    1.632154] vcc_0v9: supplied by vcc3v3_sys
    [    1.632835] vcc5v0_typec: supplied by vcc5v0_sys
    [    1.633892] iommu: Default domain type: Translated
    [    1.639032] vgaarb: loaded
    [    1.639806] SCSI subsystem initialized
    [    1.641431] usbcore: registered new interface driver usbfs
    [    1.641500] usbcore: registered new interface driver hub
    [    1.641749] usbcore: registered new device driver usb
    [    1.642533] pps_core: LinuxPPS API ver. 1 registered
    [    1.642552] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.642596] PTP clock support registered
    [    1.642908] EDAC MC: Ver: 3.0.0
    [    1.644758] NetLabel: Initializing
    [    1.644810] NetLabel:  domain hash size = 128
    [    1.645201] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
    [    1.645296] NetLabel:  unlabeled traffic allowed by default
    [    1.647425] clocksource: Switched to clocksource arch_sys_counter
    [    1.781316] VFS: Disk quotas dquot_6.6.0
    [    1.781522] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.782689] AppArmor: AppArmor Filesystem Enabled
    [    1.793093] NET: Registered protocol family 2
    [    1.794596] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    1.794770] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    1.795469] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
    [    1.796040] TCP: Hash tables configured (established 32768 bind 32768)
    [    1.796516] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    1.796664] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    1.797138] NET: Registered protocol family 1
    [    1.797188] NET: Registered protocol family 44
    [    1.797217] PCI: CLS 0 bytes, default 64
    [    1.797556] Trying to unpack rootfs image as initramfs...
    [    2.781198] Freeing initrd memory: 13000K
    [    2.794109] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    2.797503] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    2.798611] kvm [1]: IPA Size Limit: 40bits
    [    2.800077] kvm [1]: vgic-v2@fff20000
    [    2.800277] kvm [1]: GIC system register CPU interface enabled
    [    2.803032] kvm [1]: vgic interrupt IRQ10
    [    2.805929] kvm [1]: Hyp mode initialized successfully
    [    2.818658] Initialise system trusted keyrings
    [    2.818817] Key type blacklist registered
    [    2.821082] workingset: timestamp_bits=44 max_order=20 bucket_order=0
    [    2.829032] zbud: loaded
    [    2.831925] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    2.834623] fuse: init (API version 7.31)
    [    2.836620] integrity: Platform Keyring initialized
    [    2.892137] Key type asymmetric registered
    [    2.892216] Asymmetric key parser 'x509' registered
    [    2.892435] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    2.892962] io scheduler mq-deadline registered
    [    2.892981] io scheduler kyber registered
    [    2.893352] io scheduler bfq registered
    [    2.926971] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
    [    2.927429] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
    [    2.929274] dma-pl330 ff6e0000.dma-controller: Loaded driver fo
        [    3.077297] loop: module loaded
    [    3.085632] libphy: Fixed MDIO Bus: probed
    [    3.086487] tun: Universal TUN/TAP device driver, 1.6
    [    3.088594] thunder_xcv, ver 1.0
    [    3.088965] thunder_bgx, ver 1.0
    [    3.089323] nicpf, ver 1.0
    [    3.090610] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    3.091205] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    3.091791] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
    [    3.092415] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    3.092966] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
    [    3.093668] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    3.094486] sky2: driver version 1.30
    [    3.095628] VFIO - User Level meta-driver version: 0.3
    [    3.120267] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    3.120953] ehci-pci: EHCI PCI platform driver
    [    3.121402] ehci-platform: EHCI generic platform driver
    [    3.124557] ehci-platform fe380000.usb: EHCI Host Controller
    [    3.125119] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
    [    3.126214] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
    [    3.138964] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
    [    3.139902] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
    [    3.140648] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.141298] usb usb1: Product: EHCI Host Controller
    [    3.141743] usb usb1: Manufacturer: Linux 5.8.6-rockchip64 ehci_hcd
    [    3.142306] usb usb1: SerialNumber: fe380000.usb
    [    3.143640] hub 1-0:1.0: USB hub found
    [    3.144029] hub 1-0:1.0: 1 port detected
    [    3.147293] ehci-platform fe3c0000.usb: EHCI Host Controller
    [    3.147841] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
    [    3.148843] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
    [    3.162945] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
    [    3.163756] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
    [    3.164503] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.165154] usb usb2: Product: EHCI Host Controller
    [    3.165598] usb usb2: Manufacturer: Linux 5.8.6-rockchip64 ehci_hcd
    [    3.166162] usb usb2: SerialNumber: fe3c0000.usb
    [    3.167282] hub 2-0:1.0: USB hub found
    [    3.167661] hub 2-0:1.0: 1 port detected
    [    3.168828] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    3.169407] ohci-pci: OHCI PCI platform driver
    [    3.169886] ohci-platform: OHCI generic platform driver
    [    3.170787] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
    [    3.171534] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
    [    3.172549] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
    [    3.235358] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
    [    3.236104] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.236755] usb usb3: Product: Generic Platform OHCI controller
    [    3.237288] usb usb3: Manufacturer: Linux 5.8.6-rockchip64 ohci_hcd
    [    3.237852] usb usb3: SerialNumber: fe3a0000.usb
    [    3.238989] hub 3-0:1.0: USB hub found
    [    3.239367] hub 3-0:1.0: 1 port detected
    [    3.240430] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
    [    3.241053] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
    [    3.242042] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
    [    3.303173] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
    [    3.303923] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.304578] usb usb4: Product: Generic Platform OHCI controller
    [    3.305112] usb usb4: Manufacturer: Linux 5.8.6-rockchip64 ohci_hcd
    [    3.305676] usb usb4: SerialNumber: fe3e0000.usb
    [    3.306797] hub 4-0:1.0: USB hub found
    [    3.307208] hub 4-0:1.0: 1 port detected
    [    3.309425] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    3.309966] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
    [    3.310863] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
    [    3.312021] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe800000
    [    3.313186] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
    [    3.313931] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.314582] usb usb5: Product: xHCI Host Controller
    [    3.315170] usb usb5: Manufacturer: Linux 5.8.6-rockchip64 xhci-hcd
    [    3.315736] usb usb5: SerialNumber: xhci-hcd.0.auto
    [    3.316924] hub 5-0:1.0: USB hub found
    [    3.317301] hub 5-0:1.0: 1 port detected
    [    3.318091] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    3.318602] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
    [    3.319349] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [    3.320017] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
    [    3.320887] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
    [    3.321630] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.322281] usb usb6: Product: xHCI Host Controller
    [    3.322725] usb usb6: Manufacturer: Linux 5.8.6-rockchip64 xhci-hcd
    [    3.323433] usb usb6: SerialNumber: xhci-hcd.0.auto
    [    3.324425] hub 6-0:1.0: USB hub found
    [    3.324800] hub 6-0:1.0: 1 port detected
    [    3.325832] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    3.326350] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
    [    3.327269] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
    [    3.328340] xhci-hcd xhci-hcd.1.auto: irq 229, io mem 0xfe900000
    [    3.329398] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
    [    3.330144] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.330798] usb usb7: Product: xHCI Host Controller
    [    3.331327] usb usb7: Manufacturer: Linux 5.8.6-rockchip64 xhci-hcd
    [    3.331893] usb usb7: SerialNumber: xhci-hcd.1.auto
    [    3.332935] hub 7-0:1.0: USB hub found
    [    3.333310] hub 7-0:1.0: 1 port detected
    [    3.334093] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    3.334607] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
    [    3.335342] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
    [    3.336018] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
    [    3.336889] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
    [    3.337634] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.338285] usb usb8: Product: xHCI Host Controller
    [    3.338729] usb usb8: Manufacturer: Linux 5.8.6-rockchip64 xhci-hcd
    [    3.339332] usb usb8: SerialNumber: xhci-hcd.1.auto
    [    3.340308] hub 8-0:1.0: USB hub found
    [    3.340702] hub 8-0:1.0: 1 port detected
    [    3.341734] usbcore: registered new interface driver usb-storage
    [    3.345820] mousedev: PS/2 mouse device common for all mice
    [    3.348078] i2c /dev entries driver
    [    3.358057] rk808 0-001b: chip id: 0x0
    [    3.364357] rk808-regulator rk808-regulator: there is no dvs0 gpio
    [    3.364992] rk808-regulator rk808-regulator: there is no dvs1 gpio
    [    3.365647] DCDC_REG1: supplied by vcc5v0_sys
    [    3.367372] DCDC_REG2: supplied by vcc5v0_sys
    [    3.368523] DCDC_REG3: supplied by vcc5v0_sys
    [    3.369218] DCDC_REG4: supplied by vcc5v0_sys
    [    3.370209] LDO_REG1: supplied by vcc5v0_sys
    [    3.372181] LDO_REG2: supplied by vcc5v0_sys
    [    3.373796] LDO_REG3: supplied by vcc5v0_sys
    [    3.375427] LDO_REG4: supplied by vcc5v0_sys
    [    3.377085] LDO_REG5: supplied by vcc5v0_sys
    [    3.377672] vcca3v0_codec: Bringing 1800000uV into 3000000-3000000uV
    [    3.379353] LDO_REG6: supplied by vcc5v0_sys
    [    3.380978] LDO_REG7: supplied by vcc5v0_sys
    [    3.381587] vcc0v9_hdmi: Bringing 800000uV into 900000-900000uV
    [    3.383241] LDO_REG8: supplied by vcc5v0_sys
    [    3.384873] SWITCH_REG1: supplied by vcc3v3_sys
    [    3.385741] SWITCH_REG2: supplied by vcc3v3_sys
    [    3.391030] rk808-rtc rk808-rtc: registered as rtc0
    [    3.392216] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:51:23 UTC (1358499083)
    [    3.395448] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
    [    3.396130] fan53555-reg: supplied by vcc5v0_sys
    [    3.396780] random: fast init done
    [    3.400572] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
    [    3.401265] fan53555-reg: supplied by vcc5v0_sys
    [    3.426959] sdhci: Secure Digital Host Controller Interface driver
    [    3.428063] sdhci: Copyright(c) Pierre Ossman
    [    3.428496] Synopsys Designware Multimedia Card Interface Driver
    [    3.431598] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
    [    3.432311] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
    [    3.432924] dwmmc_rockchip fe310000.mmc: Version ID is 270a
    [    3.433666] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
    [    3.434836] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
    [    3.435401] mmc_host mmc0: card is non-removable.
    [    3.449692] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    3.465496] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
    [    3.466220] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
    [    3.466829] dwmmc_rockchip fe320000.mmc: Version ID is 270a
    [    3.468025] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
    [    3.469127] dwmmc_rockchip fe320000.mmc: Got CD GPIO
    [    3.483032] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    3.496804] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
    [    3.498639] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.499304] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
    [    3.501455] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
    [    3.501463] mmc2: CQHCI version 5.10
    [    3.505608] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
    [    3.509559] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
    [    3.529493] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
    [    3.540412] ledtrig-cpu: registered to indicate activity on CPUs
    [    3.542520] hid: raw HID events driver (C) Jiri Kosina
    [    3.543813] usbcore: registered new interface driver usbhid
    [    3.544348] usbhid: USB HID core driver
    [    3.554880] drop_monitor: Initializing network drop monitor service
    [    3.557351] NET: Registered protocol family 10
    [    3.568322] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
    [    3.642904] Segment Routing with IPv6
    [    3.643733] NET: Registered protocol family 17
    [    3.644567] 8021q: 802.1Q VLAN Support v1.8
    [    3.645088] Key type dns_resolver registered
    [    3.649518] registered taskstats version 1
    [    3.649909] Loading compiled-in X.509 certificates
    [    3.660045] Loaded X.509 cert 'Build time autogenerated kernel key: 5abde4b0fc662c48dfcba1e0053d7a84b8f934da'
    [    3.661625] zswap: loaded using pool lzo/zbud
    [    3.665685] Key type ._fscrypt registered
    [    3.666062] Key type .fscrypt registered
    [    3.666419] Key type fscrypt-provisioning registered
    [    3.671159] Btrfs loaded, crc32c=crc32c-generic
    [    3.710237] Key type encrypted registered
    [    3.710789] AppArmor: AppArmor sha1 policy hashing enabled
    [    3.817654] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
    [    3.818424] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
    [    3.819219] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
    [    3.820479] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
    [    3.821087] pci_bus 0000:00: root bus resource [bus 00-1f]
    [    3.821584] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
    [    3.822206] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
    [    3.823156] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
    [    3.823867] pci 0000:00:00.0: supports D1
    [    3.824235] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    3.830238] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.831339] pci 0000:01:00.0: [126f:2262] type 00 class 0x010802
    [    3.832944] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
    [    3.833811] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 223
    [    3.835034] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
    [    3.837542] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
    [    3.845127] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
    [    3.845804] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
    [    3.846437] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa003fff 64bit]
    [    3.847407] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    3.847978] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
    [    3.849392] mmc0: new ultra high speed SDR104 SDIO card at address 0001
    [    3.851622] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
    [    3.852743] pcieport 0000:00:00.0: PME: Signaling with IRQ 240
    [    3.855749] pcieport 0000:00:00.0: AER: enabled with IRQ 240
    [    3.858728] nvme nvme0: pci function 0000:01:00.0
    [    3.859484] nvme 0000:01:00.0: enabling device (0000 -> 0002)
    [    3.862212] of_cfs_init
    [    3.862581] of_cfs_init: OK
    [   64.495100] nvme nvme0: I/O 24 QID 0 timeout, disable controller
    [   64.602943] nvme nvme0: Device shutdown incomplete; abort shutdown
    [   64.604272] nvme nvme0: Identify Controller failed (881)
    [   64.604758] nvme nvme0: Removing after probe failure status: -5
    [   64.624093] Freeing unused kernel memory: 4160K
    [   64.635984] Run /init as init process
    [   65.669035] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
    [   65.669687] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
    [   65.670488] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
    [   65.671783] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
    [   65.672423] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
    [   65.672944] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
    [   65.673470] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
    [   65.674247] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
    [   65.674877] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
    [   65.680608] rk_gmac-dwmac fe300000.ethernet: init for RGMII
    [   65.682738] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
    [   65.683536] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
    [   65.684013] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
    [   65.684686] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
    [   65.685384] rk_gmac-dwmac fe300000.ethernet: COE Type 2
    [   65.685862] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
    [   65.686499] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
    [   65.687573] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
    [   65.688118] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
    [   65.688646] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
    [   66.187690] libphy: stmmac: probed
    [   66.188177] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
    [   66.189298] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
BUT! The minimal image I compiled works just fine ... aslong as I dont install webmin. Webmin is a web dashboard to configure and administer a server and I love to use it for my small Raspberry server.
But for some strange reason, armbian just wont boot after I install webmin and restart. I tried installing all the dependencies first and rebooting, that works just fine. Installing webmin itself does not. The bootlog ends exactly the same:
So, my best guess is both the default image and webmin configure something that causes these issues. Any ideas?
Edited by Youri Ulbrich
Currently we don't support direct booting from SSD - only via eMMC/SD and that one certainly works. For this way, its hard to tell. You are using u-boot that resist on the SPI chip:
... that one is likely causing troubles. At least some.
We will be providing this feature once R&D of this https://github.com/armbian/build/pull/2143 is finished.
For Webmin its hard to tell. First we would need to identify that this is a general Armbian issue or only happens on this board.
Am 7.9.2020 um 23:00 schrieb malloc:
  Inhalt verstecken
    In
    channel 0
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 1
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 0
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x82
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    channel 1
    CS = 0
    MR0=0x98
    MR4=0x2
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0x0
    CS = 1
    MR0=0x18
    MR4=0x3
    MR5=0xFF
    MR8=0x8
    MR12=0x72
    MR14=0x72
    MR18=0x0
    MR19=0x0
    MR24=0x8
    MR25=0xFF
    256B stride
    OUT
    CPUId = 0x0
    Spi_ChipId = b4018
    SpiBootInit:0
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    mmc0:cmd8,32
    mmc0:cmd5,32
    mmc0:cmd55,32
    mmc0:cmd1,32
    SdmmcInit=0 1
    SecureMode = 0
    No find bl30.bin
    No find bl32.bin
    RunBL31 0x10000
    INFO:    SPSR = 0x3c9
    PreSerial: 2
    DRAM:  3.9 GiB
    Sysmem: init
    I2c speed: 400000Hz
    PMIC:  RK808
    Bootdev: mmc 1
      aplll 816000 KHz
      apllb 24000 KHz
      dpll 800000 KHz
      cpll 24000 KHz
      gpll 800000 KHz
      npll 600000 KHz
      vpll 24000 KHz
    => run bootcmd_nvme
                Type: Hard Disk
       Image Name:   uInitrd
    Total: 76200.743 ms
    Starting kernel ...
    [  s
  Inhalt verstecken
I have a very similar problem.
Hardware Rock pi 4 c
Installing last rock pi 4 b image to nvme , the system boot fine.
after apt update and apt upgrade. The system stuck with nvme timeout.
Change dtb file from 4b to 4c, the system stuck with the same error.
installing last image for 4c, the system stuck with the same error.
Testet with 2 different rock pi 4c.
