On a fresh install of Armbian 20.08.1/Linux 5.8.5-sunxi on an OPi Zero (256MB version), total memory is 238MB according to "free -m":
root@orangepizero:~# free -m
              total        used        free      shared  buff/cache   available
Mem:            238          74          78           1          85         154
Swap:           119           0         119
238MB is not 256MB. :-)
I assume the discrepancy is due to reserved framebuffer memory, but after a bit of testing I've found that the "sunxi_fb_mem_reserve" parameter (set to "16" in /boot/boot.cmd by default) has no apparent effect.
Here's a boot with the Armbian default "sunxi_fb_mem_reserve=16":
root@orangepizero:~# dmesg | grep "command line" && free -m
[    0.000000] Kernel command line: root=UUID=442e3394-ebc5-4a14-82f8-235d74d6b2e5 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=7d536c8c-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
Mem:            238          73          82           1          81         155
Swap:           119           0         119
A boot with "sunxi_fb_mem_reserve=0":
[    0.000000] Kernel command line: root=UUID=442e3394-ebc5-4a14-82f8-235d74d6b2e5 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=7d536c8c-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=0 cgroup_enable=memory swapaccount=1
Mem:            238          74          82           1          81         154
Swap:           119           0         119
A boot with "sunxi_fb_mem_reserve=32" (the kernel default according to https://linux-sunxi.org/Kernel_arguments):
[    0.000000] Kernel command line: root=UUID=442e3394-ebc5-4a14-82f8-235d74d6b2e5 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=7d536c8c-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=32 cgroup_enable=memory swapaccount=1
Swap:           119           0         119
Now, since I'm building a headless server and have no actual use for a framebuffer and "sunxi_fb_mem_reserve=0" doesn't appear to work, is there any other way to recover the framebuffer memory?
Or am I completely off track and the memory is taken by something else entirely? ;-)
Expand
cma=96M the amount of memory to reserve for contimuous allocation. Default is 16M so you have to raise it for the Cedar ve_size to fit.
Expand
I'm not sure what you're trying to tell me, but I did a few boots with the "cma" parameter set to different values (from 64M to 144M), and it had no effect on the total amount of memory reported by "free".
Expand
It should have effect unless you set parameter wrong or this value is fixed since ...
Provide
armbianmonitor -u
after you added this parameter and I will be able to tell you more. Now I am blind.
Provide
armbianmonitor -u
Expand
Done: http://ix.io/2x7v
Notice how the "cma" parameter appears to be picked up correctly, but has no effect on the total amount of memory.
