Godfabber Posted September 16, 2020 Posted September 16, 2020 Armbianmonitor: http://ix.io/2xMt Hi! I recently upgraded the OS of my OpiZeroLTS, from the Debian Stretch Server 5.3.5 (available distro on Sunxi website) to Debian Buster 5.8.5 (downloaded from armbian webpage). Everything went well, except when I plug my USB webcam several video devices are assigned. I made a script with fswebcam to acquire still pictures from all /dev/video* and these "ghost" cameras are causing errors when the software try to open them as regular webcams. My script: for vid in /dev/video*; do output=$(basename $vid) fswebcam -d $vid -r 1920x1080 -D 10 -S 5 -F 1 --jpeg -1 --no-banner --no-timestamp --no-info /opt/images/$output mv /opt/images/$output /opt/images/$output.jpg done ____ This is the error message I get running the script: # ./capture.sh --- Opening /dev/video0... Trying source module v4l2... /dev/video0 opened. No input was specified, using the first. Unable to query input 0. VIDIOC_ENUMINPUT: Inappropriate ioctl for device mv: cannot stat '/opt/images/video0': No such file or directory --- Opening /dev/video1... Trying source module v4l2... /dev/video1 opened. No input was specified, using the first. Unable to query input 0. VIDIOC_ENUMINPUT: Inappropriate ioctl for device mv: cannot stat '/opt/images/video1': No such file or directory --- Opening /dev/video2... Trying source module v4l2... /dev/video2 opened. No input was specified, using the first. Adjusting resolution from 1920x1080 to 1280x800. Delaying 10 seconds. --- Capturing frame... Skipping 5 frames... Capturing 1 frames... Captured 6 frames in 0.17 seconds. (35 fps) --- Processing captured image... Setting output format to JPEG, quality -1 Disabling banner. Clearing timestamp. Clearing info text. Writing JPEG image to '/opt/images/video2'. --- Opening /dev/video3... Trying source module v4l2... /dev/video3 opened. No input was specified, using the first. Unable to query input 0. VIDIOC_ENUMINPUT: Inappropriate ioctl for device mv: cannot stat '/opt/images/video3': No such file or directory ____ Here is my lsusb output: Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 004: ID 04f2:b351 Chicony Electronics Co., Ltd Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub _____ typing v4l2-ctl --list-devices I get: cedrus (platform:cedrus): /dev/video1 sun8i-di (platform:sun8i-di): /dev/video0 HD Webcam: HD Webcam (usb-1c1b000.usb-1): /dev/video2 /dev/video3 The only physical device is the /dev/video2 I got some clue reading this post: https://unix.stackexchange.com/questions/512759/multiple-dev-video-for-one-physical-device but I don´t know much (i.e. nothing) about kernel compiling, drivers and etc. Does anyone know what to stop assigning video nodes to these memory-to-memory devices? Is there a way to filter the virtual devices on my fswebcam script? Thank you!
MacBreaker Posted September 17, 2020 Posted September 17, 2020 Hello @Godfabber, i think i understand your problem. First let's check lsusb master@Zero-Bk:~$ lsusb Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 002: ID 045e:0779 Microsoft Corp. LifeCam HD-3000 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS] Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ..as you can see, a usbcam is detected: Microsoft Corp. LifeCam HD-3000 What gives you a ls -ltrh /dev/video* master@Zero-Bk:~$ ls -ltrh /dev/video* crw-rw---- 1 root video 81, 0 Sep 6 12:20 /dev/video0 crw-rw---- 1 root video 81, 1 Sep 6 12:20 /dev/video1 crw-rw---- 1 root video 81, 3 Sep 6 12:20 /dev/video3 crw-rw---- 1 root video 81, 2 Sep 6 12:20 /dev/video2 or sudo apt-get install v4l-utils v4l2-ctl --list-devices In my case: master@Zero-Bk:~$ v4l2-ctl --list-devices cedrus (platform:cedrus): /dev/video0 sun8i-di (platform:sun8i-di): /dev/video1 Microsoft® LifeCam HD-3000: Mi (usb-1c1c000.usb-1): /dev/video2 /dev/video3 That means that the module sunxi_cedrus and sun8i_di has to be blacklisted... sudo nano /etc/modprobe.d/sunxi_cedrus.conf blacklist sunxi_cedrus and: sun8i_di sudo nano /etc/modprobe.d/sun8i_di.conf blacklist sun8i_di sudo reboot After reboot you see this after typing v4l2-ctl --list-devices: Microsoft® LifeCam HD-3000: Mi (usb-1c1c000.usb-1): /dev/video0 /dev/video1 so, you have now only your webcam as video-device.. ..hope it helps...
Godfabber Posted September 17, 2020 Author Posted September 17, 2020 (edited) Hi @MacBreaker, Yes, it helped a lot! Everything works fine! I'm just wondering why we need to write sun8i_di - with low dash - if the platform name is sun8i-di, with regular hyphen...¯\_(ツ)_/¯ All my seven cameras appears correctly now: # v4l2-ctl --list-devices USB 2.0 Camera: USB Camera (usb-1c1b000.usb-1.1.1): /dev/video2 /dev/video3 SMI: SMI (usb-1c1b000.usb-1.1.2): /dev/video8 /dev/video9 HBV camera: HBV camera (usb-1c1b000.usb-1.1.3): /dev/video6 /dev/video7 SMI: SMI (usb-1c1b000.usb-1.1.4): /dev/video12 /dev/video13 USB 2.0 Camera: USB Camera (usb-1c1b000.usb-1.2): /dev/video0 /dev/video1 SMI: SMI (usb-1c1b000.usb-1.3): /dev/video10 /dev/video11 HD Webcam: HD Webcam (usb-1c1b000.usb-1.4): /dev/video4 /dev/video5 The problem now is that fswebcam can't filter the metadata device (the second /dev/video* for each camera) and try to open it, outputing an error message: # ./capture.sh --- Opening /dev/video0... Trying source module v4l2... /dev/video0 opened. No input was specified, using the first. Delaying 2 seconds. --- Capturing frame... Captured frame in 0.00 seconds. --- Processing captured image... Setting output format to JPEG, quality -1 Disabling banner. Clearing timestamp. Clearing info text. Writing JPEG image to '/opt/images/video0'. --- Opening /dev/video1... Trying source module v4l2... /dev/video1 opened. No input was specified, using the first. Unable to query input 0. VIDIOC_ENUMINPUT: Inappropriate ioctl for device . . . . and so on... I found info about this bug (or feature, depending the side you are...): https://bugzilla.kernel.org/show_bug.cgi?id=199575 Quote Apparently this is a feature introduced by commit that went in kernel 4.16: 088ead25524583e2200aa99111bea2f66a86545a. media: uvcvideo: Add a metadata device node Some UVC video cameras contain metadata in their payload headers. This patch extracts that data, adding more clock synchronisation information, on both bulk and isochronous endpoints and makes it available to the user space on a separate video node, using the V4L2_CAP_META_CAPTURE capability and the V4L2_BUF_TYPE_META_CAPTURE buffer queue type. By default, only the V4L2_META_FMT_UVC pixel format is available from those nodes. However, cameras can be added to the device ID table to additionally specify their own metadata format, in which case that format will also become available from the metadata node. Now I'll try to figure out how to filter it on fswebcam or maybe I'll need to choose another webcam app. Thanks for your help! Edited September 17, 2020 by Godfabber
MacBreaker Posted September 19, 2020 Posted September 19, 2020 Hi, Quote Everything works fine! I'm just wondering why we need to write sun8i_di - with low dash - if the platform name is sun8i-di, with regular hyphen...¯\_(ツ)_/¯ i know the problem , but when you type "lsmod" you can see all aktive modules and the writing.. About the other problem. Maybe you can set a filter in your script that allow only "even numbers" and skip "odd numbers".. ..just my thougts about this. greetings Markus
