Banana M2Plus wifi and bluetooth under Armbian 20.08.7 Bionic with Linux 5.8.13-sunxi
Alex83
Hi guys,
I searched for an answer but couldn't find a working one. Most answers from 2017 and it's not possible to answer there.
Could someone please explain how to use the wifi and bluetooth module on Armbian 20.08.7 Bionic with Linux 5.8.13-sunxi (minimal without desktop)?
 ____  ____  _   __  __ ____
| __ )|  _ \(_) |  \/  |___ \  _
|  _ \| |_) | | | |\/| | __) || |_
| |_) |  __/| | | |  | |/ __/_   _|
|____/|_|   |_| |_|  |_|_____||_|
Welcome to Armbian 20.08.7 Bionic with Linux 5.8.13-sunxi
System load:   2%               Up time:       35 min
Memory usage:  8% of 998M       IP:            192.168.190.164 10.0.191.1
CPU temp:      38°C               Usage of /:    7% of 15G
Last login: Fri Oct  9 01:39:57 2020 from 192.168.190.100
root@bananapim2plus:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.190.164  netmask 255.255.255.0  broadcast 192.168.190.255
        inet6 2003:6:534c:7e44:81:41ff:fe4c:60a3  prefixlen 64  scopeid 0x0<global>
        inet6 2003:6:534c:7e44:71e3:4bfb:460:8389  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::81:41ff:fe4c:60a3  prefixlen 64  scopeid 0x20<link>
        ether 02:81:41:4c:60:a3  txqueuelen 1000  (Ethernet)
        RX packets 109091  bytes 133851996 (133.8 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 55723  bytes 43126783 (43.1 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 38
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0
        TX packets 0  bytes 0 (0.0
wg0: flags=209<UP,POINTOPOINT,RUNNING,NOARP>  mtu 1360
        inet 10.0.191.1  netmask 255.255.255.255  destination 10.0.191.1
        inet6 fdc9:281f:4d7:9ee9::1  prefixlen 64  scopeid 0x0<global>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        RX packets 67472  bytes 80627672 (80.6 MB)
        TX packets 37220  bytes 30171772 (30.1 MB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b0:f1:ec:fd:03:8d  txqueuelen 1000  (Ethernet)
root@bananapim2plus:~# cat /etc/network/interfaces
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto eth0
iface eth0 inet static
        address 192.168.190.164
        gateway 192.168.190.2
        dns-nameservers 192.168.190.2 192.168.190.100
    up ip route add 192.168.178.0/24 via 192.168.190.100
    up ip route add 192.168.230.0/24 via 192.168.190.100
    up ip route add 192.168.2.0/24 via 192.168.190.100
    up ip route add 192.168.170.0/24 via 192.168.190.100
    up ip route add 10.0.170.0/24 via 192.168.190.100
##    up ip route del default via 192.168.190.100 dev eth0
iface eth0 inet6 auto
With armbian-config there is no chance to find any wifi or bluetooth device. I didn't configure wifi or bluetooth unter /etc/network/interfaces, but I need a static IPv4 adress on eth0.
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
@Igor: Hey Igor, I read you wanted to implement the bluetooth and wifi directly into the armbian-images for supported M2plus. How did this go on and what is the actual state at the moment? I use the newest image with kernel 5.8.x Armbian 20.08.13, but there is still no wifi or bluetooth found within armbian-config tool.
Link to comment
