[ Kernel was updated, please reboot ]
Go to solution Solved by Igor,
Hello Armbian,
how does kernel update procedure work?
There is the script [1] that indicates that kernel was updated.
Is that updating procedure automatic? When does that happen? Has it user under the control?
Many thanks for clarification.
Rostislav
[1] https://github.com/armbian/build/blob/master/packages/bsp/common/etc/profile.d/armbian-check-first-login-reboot.sh
  • Solution
Its actually tied to board support package, not a kernel. In most cases this update comes together, sometimes just this package is pushed.
The change is done here and when BSP package is intalled tha file is generated.
https://github.com/armbian/build/blob/master/lib/makeboarddeb.sh#L46-L67
Not by default.
This process is triggered when you run apt update and apt upgrade or its version via armbian-config wrapper.
Absolutely.
