Where are armbian-config's wifi settings saved?
Go to solution Solved by voltagex,
  • Solution
I've configured and connected to a wifi network just fine, but I want to change the config non-interactively.
The config isn't in /etc/wpa_supplicant/wpa_supplicant.conf or anywhere else I'd expect, and https://github.com/armbian/config/ only mentions hostapd.
Where's the config stored?
Edit: /etc/NetworkManager/system-connections/[my SSID]
From what I read in the source I assume the whole wifi stuff is handled via hostapd. Did you take a look at its config files?
Yes, and no, hostapd only handles access points, not connecting to wifi as a client.
