armbian-config error in script for moving system to SATA, eMMC, NAND or USB
When executing script in version 20.08.14 Buster with Linux 5.4.72-odroidxu4 additional Data drive can't be mounted. The reason is that folder /srv/salt is not moved to new system partition. Please fix that.
Damjan
Installer was designed to transfer clean Armbian to some media of your choice - eMMC, NAND, SATA drive ... yes it cetainly has limitations, like our time/resources, but works well enough for most of the cases. Since this is amateur community made Linux and if you find that something needs to be changed, upgreade and fixed, propose changes https://github.com/armbian/config/pulls
