iav Posted October 26, 2020 Posted October 26, 2020 Currently no /dev/watchdog device on N2 with -current and -dev armbian kkernel. But watchdog present in -legacy. I see meson-wdt kernel module present on image, I transplant meson_wdt segment from dts file of legacy kernel to dev and current. diff --git a/arch/arm64/boot/dts/amlogic/meson-g12b-odroid-n2.dts b/arch/arm64/boot/dts/amlogic/meson-g12b-odroid-n2.dts index 819afc748828..18990208f269 100644 --- a/arch/arm64/boot/dts/amlogic/meson-g12b-odroid-n2.dts +++ b/arch/arm64/boot/dts/amlogic/meson-g12b-odroid-n2.dts @@ -226,6 +226,20 @@ hdmi_connector_in: endpoint { }; }; }; + + wdt: watchdog@0xffd0f0d0 { + compatible = "amlogic, meson-wdt"; + status = "okay"; + default_timeout=<10>; + reset_watchdog_method=<1>; /* 0:sysfs,1:kernel */ + reset_watchdog_time=<2>; + shutdown_timeout=<10>; + firmware_timeout=<6>; + suspend_timeout=<6>; + reg = <0x0 0xffd0f0d0 0x0 0x10>; + clock-names = "xtal"; + clocks = <&xtal>; + }; sound { compatible = "amlogic,axg-sound-card"; No success. No any sign watchdog presence. What I miss?
Solution chewitt Posted October 30, 2020 Solution Posted October 30, 2020 https://patchwork.kernel.org/project/linux-amlogic/patch/20201030180057.23886-1-christianshewitt@gmail.com/ ^ tested by the maintainers .. enjoy :) 1
iav Posted October 31, 2020 Author Posted October 31, 2020 Thank you, @chewitt, works for me! but check, isn't it a mistype — "wtd@"? Maybe, there should be "wdt"? t↔d?
