Hello.
using Armbian 5.16 opipc+
I have used ''create launcher'' from the desktop to be able to connect to wpa2 wifi.
I have rebooted around 6 times and is working each time.
I have to launch two in series.
first starts wpa_supplicant
second starts dhclient
success!.
I tried adding them to the startup,(wishful thinking)
so.
each time i run them from the desktop, it launches terminal and asks for PW. because command has
and requires sudo.
does anybody know how i can get around this?, it would be amazing if i could have them auto run,
next best would be without terminal asking for PW.
no i don't know how to write scripts.
I'm pretty happy with just the two clicks, however i need to set up another opipc+ for my little brother.
I'd like to make it as easy as possible for him.
Any help would be much appreciated.
what are you attempting to accomplish? is it automatically connect to a wifi network?
if you can tell me which desktop variant you are using, i will see what help i can offer.
things to look out for on a desktop installation:
Make sure that the user you created is in the netdev group.
There are also a couple of command lines that i could share that you would only need to run once, that will automatically bring up the wifi interface on the network for you.
so what Desktop are you using? XFCE? LXDE? MATE?
