Hello Armbian,
I am trying to build an image based on release 20.08, but kernel does not get compiled.
compile.sh docker BOARD=orangepizero BRANCH=current KERNEL_ONLY=no KERNEL_CONFIGURE=no CLEAN_LEVEL="" NO_APT_CACHER=yes BUILD_MINIMAL=no RELEASE=buster
Displaying message: * [\e[32ml\e[0m][\e[32mc\e[0m] xxx-sun50i-h6-enable-higher-clock.patch  info
Displaying message: Compressing sources for the linux-source package
Displaying message: Compiling current kernel 5.8.16 info
Displaying message: Compiler version arm-none-linux-gnueabihf-gcc 9.2.1 info
Displaying message: Using kernel config file config/kernel/linux-sunxi-current.config info
Displaying message: ERROR in function compile_kernel compilation.sh:411 err
Displaying message: Kernel was not built @host err
Displaying message: Process terminated  info
drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c:6549:37: error: ‘cfg80211_rtw_mgmt_frame_register’ undeclared here (not in a function)
 6549 |  .update_mgmt_frame_registrations = cfg80211_rtw_mgmt_frame_register,
make[4]: *** [scripts/Makefile.build:281: drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.o] Error 1
make[3]: *** [scripts/Makefile.build:497: drivers/net/wireless/rtl8189es] Error 2
make[2]: *** [scripts/Makefile.build:497: drivers/net/wireless] Error 2
make[1]: *** [scripts/Makefile.build:497: drivers/net] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [Makefile:1754: drivers] Error 2
make: *** Waiting for unfinished jobs....
Am I doing anything wrong?
Many thanks for the clarification.
Regards
Rostislav
Only master branch is expected to build flawless. Others aren't. The reason is that upstream sources may change so our patchset does not match anymore and cause issues.
If you want to compile this (older) branch you are on your own.
  • Werner locked and unlocked this topic
Does that mean that release tags v20.0x work until there is some change in upstream sources that brakes that?
So is it good practice to base the image from master at the given moment?
Many thanks.
Rostislav
Yes.
Ideally we would fork and freeze all sources depending on a specific branch but last but not least due to lack of  (human) ressources we cannot effort to do that.
Therefore are only able to maintain one branch which is master.
is it possible to build 5.8.x-sunxi kernel with current armbian master build?
Somehow 5.9.x-sunxi spidev breaks our user-land application.
Many thanks.
Rostislav
