korwin Posted November 3, 2020 Share Posted November 3, 2020 (edited) Dear Armbian community, First of all, I am aware of the fact that what I am trying to achieve is not supported, but let me ask anyway. What I am trying to do is to build my custom root filesystem for my specific embedded needs (which is pretty minimal and without systemd) while still using kernel (5.8.16-sunxi) and modules provided by Armbian. It is going great so far, but the first issue I need to figure out is why there are approximately 60 second delays between each brcmf_fw_alloc_request calls (full dmesg available here): [ 40.602927] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 40.620798] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt failed with error -2 [ 40.620821] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt [ 101.475933] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 162.808829] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available [ 162.813236] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268 On image provided by Armbian brcmfmac dmesg is exactly the same, but there are no such a long delays between brcmf_fw_alloc_request calls (full dmesg available here): [ 10.540426] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 10.549789] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt failed with error -2 [ 10.549807] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43430-sdio.friendlyarm,nanopi-neo-air.txt [ 11.103778] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1 [ 11.106615] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-11), device may have limited channels available [ 11.107934] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2016 11:30:56 version 7.45.77.h8.4 FWID 01-ee8a6268 Here is the list of modules that I'm currently using (from /lib/modules/5.8.16-sunxi): Module Size Used by brcmfmac 180224 0 brcmutil 16384 1 brcmfmac cfg80211 471040 1 brcmfmac rfkill 20480 1 cfg80211 usb_f_acm 20480 1 u_serial 24576 1 usb_f_acm g_serial 16384 0 libcomposite 45056 2 g_serial,usb_f_acm pwrseq_simple 16384 1 sunxi 20480 0 phy_generic 20480 2 sunxi Does anybody know a way to remove these delays without involving systemd at all? Maybe udev would be sufficient? Any opinions are appreciated Edited November 3, 2020 by korwin 0 Quote Link to comment Share on other sites More sharing options...
Solution korwin Posted November 4, 2020 Author Solution Share Posted November 4, 2020 It seems like the problem is caused by `CONFIG_FW_LOADER_USER_HELPER_FALLBACK` kernel option. Anyway, I have to compile my own kernel. In the kernel provided by Armbian this option is turned on. Ref: https://elrepo.org/bugs/view.php?id=671 https://bugzilla.kernel.org/show_bug.cgi?id=103201 https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1398458 @Werner could you remove this limitation from my account? I couldn't even reply to my own topic yesterday. Quote You have reached the maximum number of posts you can make per day. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted November 4, 2020 Share Posted November 4, 2020 7 minutes ago, korwin said: @Werner could you remove this limitation from my account? I couldn't even reply to my own topic yesterday. The restriction usually lifts automatically as soon as you receive a like from somebody or just wait after a few days. Though I removed it for you. 0 Quote Link to comment Share on other sites More sharing options...
