Ghorban_pirizad Posted November 4, 2020 Posted November 4, 2020 hi i try to load bootlog from /boot/mmc on orange pi lite when add bootlogo=true to armbianEnv only armbian logo show. i check u-boot and it send an erro "Unknown command 'bmp' - try 'help'" i check u-boot env and u-boot dont have bmp command. ow can I fix this.
Ghorban_pirizad Posted November 5, 2020 Author Posted November 5, 2020 On 11/4/2020 at 11:28 PM, Ghorban_pirizad said: hi i try to load bootlogo from /boot/mmc on orange pi lite when add bootlogo=true to armbianEnv only armbian logo show. i check u-boot and it send an erro "Unknown command 'bmp' - try 'help'" i compiple u-boot and fix bmp issue but now i get 'Failed to load '/boot/boot.bmp' There is no valid bmp file at the given address' what's this error mean?!! i don't change defualt bmp boot bmp file!!!!?
Igor Posted November 5, 2020 Posted November 5, 2020 On 11/4/2020 at 8:58 PM, Ghorban_pirizad said: when add bootlogo=true to armbianEnv only armbian logo show. That is kernel boot logo, unrelated to u-boot.
Ghorban_pirizad Posted November 7, 2020 Author Posted November 7, 2020 On 11/6/2020 at 12:31 AM, Igor said: That is kernel boot logo, unrelated to u-boot. thanks but now my uboot have bmp function but get the error on start u-boot what is that error mean. is the format of original /boot/boot.bmp have problem or problem is another thing. for now how we can change kernel boot logo. is there any way to change it. on other problem I have is I use usb-otg of orange pi lite as default sub and use it to run HDMI LCD. but because power delay LCD resolution by kernel isn't correct and i don't see kernel-logo on center. can I set default resolution in kernel before compile it.
Igor Posted November 7, 2020 Posted November 7, 2020 17 minutes ago, Ghorban_pirizad said: thanks but now my uboot have bmp function but get the error on start u-boot what is that error mean. is the format of original /boot/boot.bmp have problem or problem is another thing. This is not exactly an Armbian issue. I can only give you a hint (that can save you hours / days looking into the code) - BMP has different variants and depths and I think only one is supported. Worse case its a bug. 17 minutes ago, Ghorban_pirizad said: on other problem I have is I use usb-otg of orange pi lite as default sub and use it to run HDMI LCD. Since this is forum and not a professional support service I suggest you to search forums in deep and if you don't find related topic to the LCD issue, open a new one and describe everything you know about, also supply all logs. It also helps dramatically if you give something back before asking for more https://forum.armbian.com/subscriptions/ https://forum.armbian.com/crowdfunding/
