Rock64 enable 1-wire to read DS18B20 or Dallas temperature sensor
How is the 1-wire bus enabled on a Rock64 with Armbian 20.08.17 Bionic? I have enabled the w1-gpio through armbian-config. The /sys/bus/w1/devices/ folder is empty after sudo modprobe w1-gpio and sudo modprobe w1-therm.
Below is what is in the armbianEnv.txt file in the /boot directory.
verbosity=1
bootlogo=false
overlay_prefix=rockchip
rootdev=UUID=cbeeff94-c38d-4a79-b10a-3854a2470be4
rootfstype=ext4
overlays=i2c7 spi-spidev w1-gpio
In the /boot/dtb/rockchip/overlay/ directory there is a file rockchip-w1-gpio.dtbo.
I have connected the VCC pin of the DS18B20 to 3v3 physical pin 1, ground of the DS18B20 to physical pin 9, data of the DS18B20 to physical 7.
The DS18B20 address and w1_bus_master1 do not appear in the /sys/bus/w1/devices/ folder.
What more is required to see the DS18B20 and take readings?
I have already connected an 18x2 LCD to i2c and am writing information to the LCD using python.
Thank you for the help.
Perry
No needs to do any modprobe since it is the overlay that will load them ...
You need to specify GPIO1_D4 with "param_w1_pin" in /boot/armbianEnv.txt
Good evening. I added the following to /boot/armbianEnv.txt
param_w1_pin=GPIO1_D4
This is the armbianEnv.txt contents
verbosity=1
bootlogo=false
rootfstype=ext4
I restarted the Rock64. The w1 directory is not created in the /sys/bus/ directory. I have to run modprobe w1-gpio and/or modprobe w1-therm to see the w1 directory. The /sys/bus/w1/devices/ directory is empty. There is not an address or the w1_bus_master listed.
Thank you for your help
Perry
Ok ! I've never try this over on Rock64, but I did for some other Rockchip boards.
So, I've just tried and figured out that U-Boot version was not supporting "setexpr" function, so fixup script failed :
## Executing script at 0900Unknown command 'setexpr' - try 'help'
Unknown '
Unknown command 'setexpr' - tlibfdt fdt_getprop(): FDT_ERR_NOTFOUND
libfdt fdt_path_offset() returned FDT_ERR_BADPATH
I will check to see if doing new builds will provided newer U-Boot for this board ...
Alternatively, it is possible maybe to workaround by editing main DT instead of using overlay.
Or, apply overlay static to base blob.
fdtoverlay --help
Much easier ;)
