Per-Mattias Nordkvist Posted July 14, 2016 Posted July 14, 2016 Maybe this is a little off topic but I am researching and trying to find a PCB designer that can design a custom Allwinner board. Does anyone have any great leads for such a freelanser or firm? Any leads are appreciated. I love the platform and want to incorporate the system in a product I am working on but I realize that I will need to modify the board in order to fit my product. Cheers.
tkaiser Posted July 14, 2016 Posted July 14, 2016 On 7/14/2016 at 8:34 AM, Per-Mattias Nordkvist said: trying to find a PCB designer that can design a custom Allwinner board. You should be a bit more specific which SoC you're talking about. Since development efforts for some older Allwinner SoCs are pretty lightweight since 'system on modules' (SoM) exists already: https://www.olimex.com/Products/SOM/ http://wiki.iteadstudio.com/Core_AW204x http://wiki.in-circuit.de/index.php5?title=ICnova_A20_SODIMM Don't know where you are located but if in Europe Olimex and In-Circuit could help develop custom PCBs. In case you're after H3 using small boards like Orange Pi One/Lite or NanoPi NEO could be easily assembled with another PCB to unlock the full features (see this example how to add another USB port to OPi Lite -- the same way or even better through soldering even hobbyists could develop an add-on for NanoPi NEO). Or you could ask the persons/companies behind the H3 devices whether they do contract work (FriendlyARM develops the NanoPis, Xunlong Oranges and Bananas). In any case you should have a look at (missing) UL/CE certifications before doing the next step! 1
Per-Mattias Nordkvist Posted July 14, 2016 Author Posted July 14, 2016 Thanks for great input. Yes, I'm in europe. I know of Olimex but I thought they put their custom PCB business on hold? Maybe I was mistaken. I will check out In Circuit as well. Talking directly to the H3-companies would be the most tempting since these devices are basically all I need. It is just about tweaking the current boards. Removing unnecessary components and shrinking the size. Regarding UL/CE. Are any of the OrangePi's CE certified?
