Hi
What is the appropriate method to upgrade to a new release (20.11) without reimaging the SD card?
I have not attempted this before as I have mainly used Ubuntu which provides sudo do-release-upgrade
Note I am not using a VM or Docker.
Can I upgrade the kernel using the downloaded Helios64 image?
sudo apt install ./linux-image-<flavour>
Is there a way to do it using armbian-config (like there is for raspi-config)
Or do I need to download the armbian source and then compile
./compile.sh
1 hour ago, Bondy said:
Hi
./compile.sh
sudo apt-get update && sudo apt-get dist-upgrade -y
This will upgrade your unit. I rebooted after doing this, but I'm not sure that you need to.
Thank you for replying,
I was previously under the impression that apt-get dist-upgrade did not upgrade the kernel.
I thought it was the same as apt-get upgrade except that it also installed and deleted packages to satisfy dependencies.
Edited by Bondy
uname -a
Before dist-upgrade: 5.8.17-rockchip64 #20.08.21 SMP PREEMPT Sat Oct 31
After dist-upgrade & reboot: 5.9.11-rockchip64 #20.11.1 SMP PREEMPT Fri Nov 27
Am 5.12.2020 um 04:27 schrieb Zageron:
Good Morning.
is it not the same, when you upgrade it through armbian-config?
Greetings
