SSL Posted December 5, 2020 Share Posted December 5, 2020 hi, i have only one fan that spin, i have set the systemctl stop fancontrol and checked the pwm1 the value is 255, and only one who spin i can turn off the only fan spinning with value 0, but i can't control the seconds fan at all, i have verified the connectique on the board and everything is fine, when i opened it and checked without disk , and i saw that both fan was spinning, so i thought it was fine, when i closed the board and disk's are on, i again have the same issue, i can control only 1 fan, it's always the same one. any idea how to fix this issue? is it a software related? 0 Quote Link to comment Share on other sites More sharing options...
SSL Posted December 7, 2020 Author Share Posted December 7, 2020 My bad, a Cable was Preventing the fan from spinning, this topic could be closed! 2 Quote Link to comment Share on other sites More sharing options...
TRS-80 Posted December 7, 2020 Share Posted December 7, 2020 (edited) There is apparently no way to mark solution in this "Club" sub-forum, however thank you for reporting it back anyway. Edited December 7, 2020 by TRS-80 0 Quote Link to comment Share on other sites More sharing options...
