NanoPi R2S - OTG g_serial(ttyGS0) not working
Armbianmonitor:
Object: Enable OTG serial console capability( It was enabled by default I think )
What I was checked/tested:
 g_serial on /etc/modules
 ttyGS0 on /etc/securetty
 serial-getty@ttyGS0.service enabled
 dwc3-0-host enabled/disabled
 Windows 10 1809 host g_serial recognized R2S as 0525:A4A7(rev0509)
Behavior:
   OrangePi-Zero:  Works well( g_serial recognized as same VID/PID but rev0419 ) <== There are no problems on Windows host driver or configurations[ELMO GMAS(5/4/2014, v2.0.0.1) / usbser.sys(v10.0.17763.1)]
   NanoPi-R2S: Connection fail. Even manual configure 9600 through 115200 bauds. => Putty alerts few minutes later 'unable to configure serial port'
20201211.03:52:54 root@nanopi-r2s:~# lsmod | fgrep g_serial
g_serial               16384  0
libcomposite           81920  2 g_serial,usb_f_acm
20201211.03:52:55 root@nanopi-r2s:~#
20201211.03:52:57 root@nanopi-r2s:~# ps auxf | fgrep tty
root      1204  0.0  0.3   8672  3284 ttyS2    Ss   03:49   0:00 /bin/login -f
root      1375  0.1  0.4   7920  4560 ttyS2    S    03:49   0:00  \_ -bash
root      1501  0.0  0.2   8524  2780 ttyS2    R+   03:53   0:00      \_ ps auxf
root      1507  0.0  0.0   5820   632 ttyS2    S+   03:53   0:00      \_ grep -F tty
root      1212  0.0  0.1   5300  1328 tty1     Ss+  03:49   0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root      1219  0.0  0.1   5072  1756 ttyGS0   Ss+  03:49   0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyGS0 linux
20201211.03:53:01 root@nanopi-r2s:~#
20201211.03:53:03 root@nanopi-r2s:~#
20201211.03:53:04 root@nanopi-r2s:~# systemctl cat serial-getty@ttyGS0.service
# /lib/systemd/system/serial-getty@.service
#  SPDX-License-Identifier: LGPL-2.1+
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
[Unit]
Description=Serial Getty on %I
Documentation=man:agetty(8) man:systemd-getty-generator(8)
Documentation=http://0pointer.de/blog/projects/serial-console.html
BindsTo=dev-%i.device
After=dev-%i.device systemd-user-sessions.service plymouth-quit-wait.service getty-pre.target
After=rc-local.service
# If additional gettys are spawned during boot then we should make
# sure that this is synchronized before getty.target, even though
# getty.target didn't actually pull it in.
Before=getty.target
IgnoreOnIsolate=yes
# IgnoreOnIsolate causes issues with sulogin, if someone isolates
# rescue.target or starts rescue.service from multi-user.target or
# graphical.target.
Conflicts=rescue.service
Before=rescue.service
[Service]
# The '-o' option value tells agetty to replace 'login' arguments with an
# option to preserve environment (-p), followed by '--' for safety, and then
# the entered username.
ExecStart=-/sbin/agetty -o '-p -- \\u' --keep-baud 115200,38400,9600 %I $TERM
Type=idle
Restart=always
UtmpIdentifier=%I
TTYPath=/dev/%I
TTYReset=yes
TTYVHangup=yes
KillMode=process
IgnoreSIGPIPE=no
SendSIGHUP=yes
[Install]
WantedBy=getty.target
# /lib/systemd/system/serial-getty@.service.d/10-term.conf
[Service]
Environment=TERM=linux
20201211.03:53:21 root@nanopi-r2s:~# armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/2Hvq
Please post the URL in the forum where you've been asked for.
We plan to refresh device tree in upcoming 5.10.y kernel (welcome to help out) ... currently we still sit on early implementation, taken from FriendlyElec legacy kernel. There is a refreshed DT in DEV kernel. You can try to build from sources or just use nightly builds, but you need to set: fdtfile=rockchip/rk3328-nanopi-r2s.dts in /boot/armbianEnv.txt
Try. If you manage to get it working, patch cleanup, moving away from our 1st implementation, adding what we added ... https://github.com/armbian/build/tree/master/patch/kernel/rockchip64-dev
Thanks for your very detailed informations.
I also suffered poor entropy too. It really sounds great.
I really wish to test dev branch kernel /w new device trees and hwrngd support.
But, actually I have no Armbian build environments as for now. :(
I will wait until nightly or stable releases.
Branch "desktop", which is going to be merged in 1-2 months, also supports native arm64 compilation. You can build things on your board. No excuses :) (but its currently in WIP state so it might break)
What we don't have are resources to deal with "everything". Plans to implement this or that can easily be extended over few releases. A year can slip by and there are slim chances that features just show in mainstream.  Sometimes they do, but usually much later.
