I can not write armbian to a flash card
Go to solution Solved by neo4511,
That is normal. Unlike other distros Armbian does not use crappy stone-age FAT32 filesystem on sd card. Simply put it into your SBC and it will work.
Also normal. You cannot directly connect a pc and a SBC and expect it to work oob. Either connect both to a network with available DHCP server or use serial console to set a fixed IP address on the SBC manually.
