Download old images
Go to solution Solved by NicoD,
I'm trying to install Armbian on my OrangePiZero but i have networks issues. After 3/4 hours of tests and search i found on a forum that the problem came from the kernel version. And the person said it works with:
"Armbian_5.30_Orangepizero_Debian_jessie"
Where can i download this rom please ?
The problem:
When i start my OrangePiZero i don't have ip (i use USB/TTL to access to command line). I tried to set static ip, dhcp, i tried to remove networkmanager, to use dhcpcd instead of dhclient, etc...
I also tried wifi, but same...
Thanks !
Edited by Jonathan Gtd
  • Roberto46 changed the title to Download old images
33 minutes ago, Kalypox said:
I found an alternative, it's good
Well, would you care to share, for the benefit of others who may come along later?
GOOD EVENING TO YOU @NicoD (alias Mr impolite ;))
Not sure what to make of this, maybe you guys know each other and this is some kind of inside joke?  Maybe just trying to be funny?  I try to assume good intent, however...  Otherwise I think uncalled for towards someone who is trying to help you?
Edited by TRS-80
